Results 1 to 16 of 16
Thread: Rear brake locking up
    LX User Whitehonda's Avatar
    Nov 2002
    Then (89 LX-i) Now (94 EX)
    Michigan
    After I leave my car sitting for a peroid of time (a week or more) and I come back to drive it, the rear right brake locks/or freezes up. It is loosened with moving the car back and forth a few times, but I was wondering if anyone knew a way to prevent it from locking in the first place.
    Thanks
    Cameron
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    I don't think there's really any way to stop that from happening. It'll happen to any car that sits for awile, the brakes will form a thin layer of rust and get stuck. Just have to drive more often!
    -Jared
    Nov 2002
    Michigan
    Yeah, it's usually driven everyday, but I was in Colorado for a little over a week (went skiing Weee) and thats why it got locked up.
    Thanks Jared
    Oct 2001
    87 Accord EX , 5spd , Manual
    well if it does it again ! i woud spray some of WD- 40 on the springs ( drum brakes ) you ment E-brake right ! ?
    MIKE
    Nov 2002
    Michigan
    Yeah it is the right rear drum. I am gona take it apart one of these nice summer days and paint the drums anyway, so I might as well do it then.
    Cameron
    LX User XXFearThisXX's Avatar
    Mar 2003
    1987 Nissan Pulsar Nx Se
    Pensacola Florida
    well im sure everyone knows u dont leave your car sitting a while with the E-Brake on but if u dint have it on then just get some Wd-40 in that biatchhhhhh lol
    Well I'm sure that everyone knows it's not an E- Brake, it's a handbrake.
    SEi User maxoutracer's Avatar
    Jan 2003
    1989 Honda Integra LS-ZC
    San Francisco, CA
    rust is the main factor when it comes to brakes. i have all disc brake on my 88 integra, i just recently installed new bembo rotor and it already showing rust around the edge. back when i had 89 LXi i would remove my drum and give it a good wash with brake cleaner. also check your ebake if you have enought free play for the e brake cable, might need adjustment.
    JDM CONCEPTwww.jdmconcept.com
    1991 Honda Integra LS-Special
    Mar 2003
    88 Accord LX-I
    Pipersvile, PA
    I had the same problem a few months ago, the brake kept locking up and i found out that the brake cylander was blown, i had to get that replaced. it sounds just like what mine did.
    88 Accord LX-I
    Spoiler from SE-I Accord
    Auto-manual swap and Rear disc conversion
    May 2003
    05 Legacy GT 87/accord/lx (rip)
    boston
    Re: Rear brake locking up
    [thread hijacking]
    Hey guys, I'd like to get some opinion on a rear break lock up issue I'm having with my 5g. Yeah, I know it's not a 3g but the principles are still the same. Besides, I trust you guys and miss being active on 3geez
    My rear passenger brake has been locking up (i think on and off). I thought it was a bad caliper, so I had the calipers/pads/rotors replaced. Still does the same. I think it is just rear passenger, and maybe it is locked up all the time. Now I can hear an awful grinding sound at low speed, and a squeal a higher speed. Only from rear passenger.
    Here's the kicker. The ebrake would be loose occasionally (no effort to move it half way up), as if someone locked it down. Now I don't know if I should look at it as a brake controlling issue (master cylinder), or ebrake cable sticking issue. Don't know if it is cold weather related, but may be the case.
    Input would be greatly appreciated. I've never encountered such a problem on my 3g (rip). The worse I've had to deal with was a locked up front caliper piston.
    Thanks!
    [/thread hijacking]
    Nov 2002
    Michigan
    I actually have a 5th gen EX at the moment, and I had the same problem about a year ago. The rear discs were not even really doing their job. Everytime the parking brake is used the rear brakes are adjusted, if this is not done regularly (or at all) they can get out of adjustment.
    I eventually got frustrated and just bought new rear calipers and rotors and replaced them as a unit and it has been great ever since.
    Cameron
    May 2003
    boston
    What do you mean the rear brakes get adjusted every time the lever is pulled? Is there a way to know if it is the bad parking cable or the master cylinder that is causing this problem.
    Nov 2002
    Michigan
    Master cylinder would not affect rear brakes directly. If the MC is bad, usually it is felt in the pedal (i.e. internal master cylinder leak is common on older accords) causes the pedel to sink a little or feel spongey.
    The pads and dics both wear and need to be adjusted as they do so. Honda made it so the pads "auto adjust" or check themselves everytime the parking brake is used.
    How old are the rear calipers? Do they seem to grab well and make a smooth clean spot of the rotor? Or is it spotty and not consistant?
    If spotty I would suggest replacing the rear calipers with new/rebuit ones (as a unit) and while you are doing so it would be a wise investment to replace the rotors if you plan to keep the car for awhile.
    Bottom line, is that over time the parts stick and rust and need to be replaced.
    Let me know if I can help further, I think I have a pic of my brakes before and after if you need.
    Cameron
    May 2003
    boston
    ok, that makes more sense. The calipers+pads+rotors were just replaced with no result. One of the brakes is still grabbing. The brake pedal itself is softer now, but I think the shop did a poor job bleeding the brakes, so I'll have them do it over.
    Bottom line is that is there a component that distributes brake pressure to individual brake side in the rear? It would make sense that that part went fubar. Anyone know? Thanks guys.
    Edit: I'm going to replace the parking brake for the right side and see if that solves the problem. After looking at the brake diagram, it is entirely possible that a faulty cable is causing a lockup. I'll let you guys know.
    Nov 2002
    Michigan
    The only other thing I would check is the brake proportioning valve. This splits the brake circuit (for example the right front and left rear brake would be on the same circuit, and the left front would be paird with the rear right brake.
    Just a thought...
    Check the link below to give an idea of location and function.
    http://www.honda-tech.com/zerothread...int&id=2172747
    Cameron
    May 2003
    boston
    Got it solved after replacing the ebrake cable!
    For future reference, another possible cause for this type of problem (individual caliper locking up) is a defective brake hose at that caliper.
  1. Replies: 21
    Last Post: 04-17-2006, 07:02 PM
  2. Brake locking up a bit.
    By mag_pbg in forum 3geez Accords
    Last Post: 09-13-2004, 05:54 PM
  3. rear brake scraping
    By qh187 in forum 3geez Accords
    Last Post: 09-11-2003, 01:08 PM
  4. emergency brake/ rear brake troubles
    By THE_LoserNextDoor in forum Performance
    Last Post: 07-03-2003, 04:51 PM
  5. AEM Rear big brake kit How-to
    By guaynabo89 in forum Performance
    Last Post: 06-26-2003, 01:28 PM
VigLink badge
