I opened up my valve cover, and looked at my valve lash agian, this past monday (memorial day). I got to the 4th cylinder and, oh $hit! I stripped one of the studs and nuts. Well, needless to say, I had exams on tuesday and wednesday, so I needed to have a car. So I followed through with my old man's idea of using lock-tight on the stud. Well, needless to say, I was scared as $hit on tuesday when I drove to school (only a few minutes away). But I made it there and back, and ther and back again. I borrowed my old man's van as soon as he got off work, took off to the junk yard, and found an engine sitting in one of their garages, collecting dust. (and rat $hit). I pulled out a couple of those studs and nuts, then paid $5, got home, and finished my project.
That's besides the point. I'm posting this because I had some trouble when I had to rotate the crank to the needed position. Which way do you turn the camshaft gear? Well, here's a picture that will (hint, hint!) hopefully make it into the FAQ section.
The arrow indicates the direction the camshaft should be rotated to the next position (which is 90 deg. from top position. 'UP' should line up with head surface) Firing order is 1-3-4-2.
(so going around counterclockwise, you will adjust 1 first, then 3, then 4, then 2.
if anyone feels or knows this is wrong, please post. (maybe I did something wrong)
