Results 1 to 20 of 20
Thread: rear Disc Conversion IS IT REALLY NEEDED?
    Mar 2003
    Lightbulb rear Disc Conversion IS IT REALLY NEEDED?
    alright, I wana convert to rear Discs on my 87 LXI hatch. from what I read on the how to, I need SEI rear Controll arms and all atached hardware. Calipers. controll arms, brake Lines. blah blah blah.... know it says I need to upgrade the master Cylinder, and rotors and such..... ok.
    Master cylinder from the SEI or what???
    Bigger rotors and Calipers??? Thats ALOT to change. heh, for just the Rear discs. is it A MUST???? or just a sugestion?????
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: rear Disc Conversion IS IT REALLY NEEDED?
    A must, well no. Will it improve braking performance, yes. Car makers add them on to their hotter FWD cars for a reason. But if you don't plan on pushing your car much, you've got allot less of a reason. Oh course they do look cooler, not being sarcastic, cause they really do make the car look nicer. If you want to improve braking performance with out doing the rear disk swap, get brembo front disks (maybe do the 88-89LXI front brake swap) and high performance pads like EBC or Axxis. I got a big improvement that way, so much so that I moved rear disk's from must have NOW, to a latter date.
    Now I d
    SEi User Morpheus's Avatar
    Jan 2003
    1988 Honda CRX Si
    rear drums make your car look crappy, cheap, and low performance IMO.
    You will never get really good braking performance out of the drums, if you switch to rear disks you can upgrade those to go along with the front.
    Banned Tim Yoak's Avatar
    1986 accord hb IHAVE A HOME PAGE SEE MY PROFILE
    moultrie, ga
    who makes a kit to upgrade the rear discs? also you shouldn't have to change the master cyl. just the proportioning valve. I have a hatch and they are different then a sedan. I bought a sedan front caliper from the junkyard, rebuilt it, then found out it didn't fit. it looks like all the hatches are the heavy duty front brakes.
    Oct 2001
    87 Accord EX , 5spd , Manual
    BTW they look crappy if you have 17 " wheels on your car ! !
    MIKE
    Central California
    No one makes a rear disk brake upgrade, you make it by pulliing the parts off a SEI model at the junk yard.
    86-87 LXI's have smaller front brakes than 88-89 LXI's.
    Your comment on the master cyl makes sense, I wonder if it's the same part#, if not I'd say you do need to pull it.
    Now I d
    Jan 2003
    1988 Honda CRX Si
    Does Honda remanufacture parts?
    Could you order some OEM replacements?
    Mar 2003
    ok, so Proportion valve, and upgrade Brake Rotors, I think im going to start Collecting all the parts, and when my tires ware down, Ill order my 17's and do the Whole conversion.
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    No, not really. You can get an aem rear upgrade kit. That is if you already have rear discs though.
    Central California
    As you put it, good point.
    Now I d
    Mar 2003
    ok, I found SEI rear hardware, What should I ask for???? anything that might be over looked???? thanks, whats a fare price on the whole setup??? its going to be shipped, what Decent Shipping Price???? its from a 89 SEI does it fit Directly to the 87 Hatchie??? thanks.
    guaynabo89's Avatar
    FL
    Both hubs, calipers, brake lines(some junkyard cut em to drain fluids), e-brake cables, master cylinder, proportioning valve, and rotors.
    You really don't need the whole trailing arm, but if its the same price just get it. It might have better bushings since its two years newer than yours.
    SEi User maxoutracer's Avatar
    Jan 2003
    1989 Honda Integra LS-ZC
    San Francisco, CA
    wonder if the 86-89 integra rear disc brake will fit, hummm... wish i still have my 89 LXi to try them out, hehe...
    JDM CONCEPTwww.jdmconcept.com
    1991 Honda Integra LS-Special
    guaynabo89's Avatar
    FL
    I don't think so. The sei rear brakes are closer to the90-93 tegs. The 1st gen tegs use a bar to tie the two wheels correct? I think that would make it more complicated.
    Jan 2003
    1988 Honda CRX Si
    wot about ordering OEM parts? Honda has to remanufacture stuff like that.
    guaynabo89's Avatar
    FL
    I doubt they would have the knuckle assembly. If they did it would probably cost as much as the car.
    As far as evrything else, it should be easily had at a local dealer. The question would be, are you really willing to pay that much for new parts?
    Feb 2003
    1989 Honda Accord LXi
    Oklahoma
    yo pogi, where are u getting the sei parts? None of the salvage yards in my area have any. Do u know if they had more?
    Mar 2003
    From this Dude Parting one out, I dont know if he has more, Ill ask him though
    Jan 2003
    San Francisco, CA
    true, we use beam axle, i remember my LXi has rear wishbone arm, so i guess it won't fit. why not get it from the 90-93 integra, i see alot of them in the junk yard, hehe...
    Feb 2003
    Oklahoma
    thanks, give me a yell if u find out anything!!:super: :super:
  1. rear disc conversion
    By buttaz1 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-15-2006, 04:14 PM
  2. SEi rear disc conversion help
    By buish in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-06-2004, 06:49 PM
  3. Rear disc brake conversion
    By 86nate in forum Performance
    Last Post: 08-15-2003, 09:38 PM
  4. rear disc conversion EXACTLY DO I NEED?
    By PogiLXI in forum 3geez Accords
    Last Post: 04-29-2003, 08:52 PM
  5. For those with the rear disc conversion:
    By DarknessRS in forum 3geez Accords
    Last Post: 10-09-2002, 01:19 AM
