Results 1 to 7 of 7
Thread: power problem?
    Feb 2003
    1989 Honda Accord LXi
    Oklahoma
    power problem?
    while my car is idling at about 850, if I push on the brake pedal or turn on th lights, or use the windows my car will drop a couple hundred rpm and begin to shutter. NE 1 have ne ideas as to what the hell this might be?
    88/honda/accordlx-i hatchback
    Could be an alternator problem have you checked it?
    shepherd79's Avatar
    Falling Waters, WV USA
    make sure you have solid ground on the battery.
    LXi 1987 Fuel Injected Sedan
    Lynchburg VA
    Dude my car does that too, I have have a great ground connection but i dont know what else it could be, the alternator sounds like a great idea but it doesnt bother me enough to go put one on.
    Bruce
    Engine Mods:
    Milled the head
    Advanced Timing
    Adjustable fuel pressure regulator
    New Injectors
    Cool Air and Ram Air kit
    Dismantled EGR Valve
    Pace Setter Header 4-2-1
    No Cat into a Pace Setters muffler
    1988starter
    Guest
    I think when you press the break it changes the vacume try pumping it real fast.
    MoBFiGGa
    Guest
    :pimp: you should check your ecu fuse under the hood if u were fckng with radio stuff or anything like that acasionaly you can blow that fuse. if thats what it is your car will now run like a raped aped after u fix it
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    might want to check your EACV
  1. go power problem
    By headbanger in forum 3geez Accords
    Last Post: 06-28-2009, 11:46 AM
  2. power problem?
    By cameron7710 in forum 3geez Accords
    Last Post: 10-27-2008, 10:56 PM
  3. no power (electrical_ problem)
    By spanky in forum 3geez Accords
    Last Post: 08-11-2006, 04:47 AM
  4. Problem with loss of power
    By diablo75 in forum Carburetor Tech
    Last Post: 07-28-2005, 10:41 PM
  5. power problem-HELP!
    By RSXtacy in forum 3geez Accords
    Last Post: 12-08-2004, 04:49 AM
