Results 1 to 2 of 2
Thread: Vaccum lines from distruuter to carb manifold
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    when u remove all the emission vaccum lines and u run the 2 lines from the distruibuter to the back of teh manifold what do u use to make them into one and bigger to go around the larger opening on the manifold.
    also if that part is leaking vaccum a little what problems could i have? cuz mine is leaking cuz i ghetto rigged it together.
    thanx
    shepherd79's Avatar
    Falling Waters, WV USA
    well, i got adapter to connect thicker vacuum line to manifold and thiner one to the distributor and carb.
    just got o your local parts store and look for vacuum adapters.
    you are leaking vacuum, you will have bad idle or in some cases no idle at all.
  1. Vaccum Lines ????
    By #82 Accord in forum 3geez Accords
    Last Post: 12-07-2006, 06:19 AM
  2. vaccum lines
    By Magny in forum Carburetor Tech
    Last Post: 08-07-2004, 05:29 PM
  3. Help with Vaccum lines
    By kevins89lxi in forum 3geez Accords
    Last Post: 08-27-2003, 12:42 PM
  4. vaccum lines
    By franks89sir in forum 3geez Accords
    Last Post: 07-02-2003, 07:00 PM
  5. carb manifold: bypassing the coolant lines
    By POS carb in forum Carburetor Tech
    Last Post: 04-09-2003, 08:20 PM
