Did a search and apparently the horn and cruise control work together, and if one is bad the other will go. Well that was the jist of what I read.
So, the green cruise light on the push buttom does light up. Nothing happens on the dash when I hit my steering wheel buttons.
Yes my horn is also dead. The wiring in the steering wheel is fine (did a manual wire test with the horn cover off).
So, I'm going to check the cruise switch under the brake pedal to check.
The cruise/horn 7.5A fuse is fine.
Any other suggestions to check?
