Results 1 to 10 of 10
Thread: rack n pinion
    Jan 2003
    87 lxi
    N.O.L.A.
    Unhappy rack n pinion
    How much do u think it would cost to get my rack n pinion, upper and lower ball joints replaced. i know it would be more beneficial for me to do it on my own, but i am too ignorant as far as suspension work goes to do it myself or without any supervision so what do i do.
    "I'm rolling, car not stolen, probably never will cause it's much too olden',"..... Devin the Dude
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    reach real far down in ur pockets...
    ...that steering rack is not a cheap job.
    the ball joints on the other hand are not that expensive. Just call around to local shops and get a quote. Tell 'em exactly what you want done and to give you a price. Also ask what brand b/j's they'll be using, and what thier warranty and the product warranty is. For the rack, be sure to ask if they'll be installing a re-man'ed rack, or a new. If new, is it a genuine honda, or an oem spec aftermarket.
    -Mark D.
    Oct 2001
    87 Accord EX , 5spd , Manual
    rack n pinion ! ouch ! that hurts !
    MIKE
    Nov 2000
    It depends upon how high quality of a rebuilt rack you want. you can order Honda rebuilt racks online for abour $313. The honda shop in town I trust uses a rebuilder he likes that also sells them for about $300. He says that Honda's rebuilt rack is the best, bar none, and that he would install one for me if I chose to purchase it on my own.
    I called NAPA and they sell a rebuilt rack for $150. What the differences are between that one and one from Honda, I don't know. I did look at the ones on eBay that someone posted here recently. They were $100 and said something about "stainless sleeved." Apparently, this means that something inside is fucked and had to be sleeved. Again, I have no idea if this makes for a good, long lasting rack unit or not.
    The local shop gets something like $250 for labor to install. It would be quite a job indeed without a rack as you have to pull the exhaust head pipe and center beam to get the thing out.
    Jan 2003
    87 lxi
    N.O.L.A.
    Dude, I know. This job is gonna suck so bad. It's bad to the point to where my camber is off on my car and there is no way for me to fix it or is there? :
    Nov 2000
    Steering rack problems would cause you toe problems. Ball joints would be more the culprit for camber problems, unless your camber has been off from day one like mine was before I installed the camber kit.
    Anyway, I know about the steering rack affecting the toe because I just pulled my tie rod ends to replace both boots on my steering rack. Even though I measured before pulling them I still had to take it in for an alignment to fix the toe on both sides when I got done.
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    Some guy slammed into my car the last snow storm we had, hje hit my driver's side tire and bent the tire rod into a 45" angle and fucked up the ball joint and steering rack. The insurance is paying for pretty much everything except the deductable. But the steering rack they had to buy new and that shit cost $620 bucks brand new from Honda, not rebuilt.
    R.I.P. Died on 7/2/03......
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    Stainless sleeved refers to the parts in them that were originally nickle sleeved copper that stretched out over time; I believe it was the outer arm pieces.
    I just said to hell with it and am getting a manual rack
    1/2 JDM B18A DOHC CARB
    MD
    Moonscryer:
    May I ask where did you get the manual steering rack from?
    I'm looking for one too.
    Carl
    MD
    Nevermind, I searched and found a previous link for carotman selling manual rack.
    Carl
  1. rack n pinion
    By allaces in forum 3geez Accords
    Last Post: 10-15-2012, 01:48 PM
  2. Rack and Pinion
    By -$MOKIN- in forum 3geez Accords
    Last Post: 04-30-2011, 07:24 AM
  3. Rack and Pinion
    By dalinxz in forum 3geez Accords
    Last Post: 04-23-2007, 11:03 AM
  4. Rack n' Pinion?
    By Chris86Lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-26-2003, 09:44 AM
  5. Rack and Pinion
    By c20v6turbo3rdgen in forum 3geez Accords
    Last Post: 04-08-2003, 10:09 PM
