Results 1 to 4 of 4
Thread: lag at 3000 RPM
    88 Prelude Si with 4WS
    Cherokee County
    lag at 3000 RPM
    I am having a lag at 2700 and 2900 and then when I get to 3000 the power is alot better. When I am going up hill or if the car is trying ithe whole car jerks hard. I have had that happen in 4th and 5th. I have a LX-i 5 speed if that helps. I don't know what to do. I have put Bosch Plat. 2 plugs and Bosch wires in it. I had someone tell me that the timing was off. He took a timing light on it and then after that he put a bar on the dist. and hit it with a hammer. It worked for a long time and then it started to happen again. I asked him about it and he told me to put some premium in it. I am stumped.
    1988starter
    Guest
    Check your timing again and make sure it is set right also try premium it helps resist detonation.
    Cherokee County
    what do you mean detonation?
    *Content exceeds signature guidelines*
    88 Prelude Si with 4 Wheel Steering and a JDM B20A
    1988starter
    Guest
    When gasoline ignites due to compresstion not spark that is why high comp vehicals need high octane or something
  1. $3000+ car repair!
    By LXlimited in forum 3geez Accords
    Last Post: 05-06-2007, 09:14 AM
  2. car stumbles above 3000 rpm
    By alexkol in forum 3geez Accords
    Last Post: 08-04-2005, 07:19 PM
  3. Cutting at 3000 RPM?
    By Richy833 in forum 3geez Accords
    Last Post: 03-24-2004, 07:37 PM
  4. 3000 rpm
    By c20v6turbo3rdgen in forum Performance
    Last Post: 04-15-2003, 09:15 PM
  5. ??? @ 3000 rpm...
    By DarkkManX in forum Performance
    Last Post: 07-01-2002, 11:45 AM
