Results 1 to 3 of 3
Thread: brake booster
    87 LXi Hatch (5-speed)
    Riverside, CA
    brake booster
    i think my brake booster maybe going out. I have done the test where you turn off the car and then press on the pedal. I gets hard, but if i push a little harder it goes down further. could it be that i'm just pushing to hard? Is there a way to increase the amount of "boost"? Is there another way of checking?
    thanks for your replies in advance!!
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    Not sure u've done the booster check correctly, cuz it needs vacuum = engine on! The way u checked it might prove that is air in the brake system or some fluid leak..
    To check the vacuum booster, pump the brake pedal with the engine off until you've bled off all the vacuum from the unit. Then hold the pedal down and start the engine. You should feel the pedal depress slightly as engine vacuum enters the booster and pulls on the diaphragm. No change? Then check the vacuum hose connection and engine vacuum. If okay, the problem is in the booster and the booster needs to be rebuilt/replaced.
    SiR's Avatar
    Jul 2002
    87 Accord LX
    Fort Lauderdale, Florida
    Many times the reason the booster went out on you is cuz the the master cylinder started leaking into the brake booster and cuz the booster to fail. You might have to replace both. You'll findout when you have to remove the booster if you need to. The shaft will be coated with brake fluid, not good.
    P.S.: Does it require more force to brake when the engine is running and doe sit make any noise when you press the brakes when also the engine is running?
    Rooz
  1. Wet Brake Booster
    By bushbean in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-12-2009, 05:33 PM
  2. brake booster
    By 87newb in forum 3geez Accords
    Last Post: 05-22-2008, 02:24 PM
  3. Brake Booster
    By HondaBoy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-29-2007, 08:02 AM
  4. Brake booster...
    By ahbeyra in forum Carburetor Tech
    Last Post: 07-19-2003, 05:05 AM
  5. brake booster
    By 86accordlxi-fi in forum 3geez Accords
    Last Post: 01-15-2003, 12:29 PM
