Results 1 to 17 of 17
Thread: Engine Stalling
    Honda Accord 1989 LX
    Arkansas
    Angry Engine Stalling
    Hi,
    I have an accord 1989 LX with a manual transmission.
    When I start my car it works fine. It idles between 2000 and 2500 when cold I think...
    When it get warmer it will stay around 900, 1000 and as soon as I press on the clutch and stop at a stop light the engine stalls. I have to press on the gaz pedal to make it rev higer so it wont stall. As long as I am driving, it is fine but as soon as I get close to a stop light and the car slows down it wants to stall. It is awkward but sometimes if I slow down staying in gear with my foot on the clutch it will die but SOMETIMES if I slow down and put it in neutral and just use the brakes it doesnt stall as often...
    Today I bought something to clean the fuel system and carburetor and put that stuff in my gaz tank and it ran a lil better at first and a couple of hours later it didnt stall.
    It is weird because it looks like it runs ok for a while and as soon as I want to stop it can stall. Do you have any suggestions?
    By the way I put brakes on my car and we also bled them but all the time my brake pedal can go all the way to the floor but right after I will press on it again and it seems to be back to normal.
    what could it be? the master cylinder or something?
    Thanks!!!!!
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Well try Seafoam and if that doesn't work then get a Weber!!!! Oh forget the seafoam.
    Oct 2001
    87 Accord EX , 5spd , Manual
    i would check for vacuum leaks ! specially teh master cylinder's !
    about the brake pedal it's propably there is still air in the system !
    BTW YOU DON'T NEED TO remove brake line's to replace brakes ( except for replacing the caliper it self !
    MIKE
    Mankato, Minnesota
    I might have a vacuum leak, but I tried listening for it but there would have to be a miracle for me to hear a vac. leak over my engine purrrr.
    shepherd79's Avatar
    Falling Waters, WV USA
    check your coolant level too.
    Arkansas
    So, if it dies as soon as I slow down and stops and it can be a vacuum leak?
    Oct 2001
    yes ! and check coolant level as Alex suggested !
    MIKE
    1988 Honda Accord LX
    Bethlehem P.A
    i kinda have the same problem but its not when i go to stop its when i turn. it just stalls! flat out dies but turns right over when i turn the key. any help would be nice. i was going down the high way it just pfft! and died i heard the sound of it going to die again and i put in the clutch and started it and it was fine again. i am soo lost on what it is.
    You want this!? You can't handle this! 0-60 in 2 miles! hellz yah
    May 2003
    1986 Honda Accord LX
    I seem to have the same problem with my 86 Accord LX. It starts fine then stalls when I slow down to stop or make a turn. Unfortunately, the problem appears somewhat intermittent (it stalls less if it's been sitting for a few days) and no mechanic has been able to diagnose the problem. They tried cleaning the carb and gas filter but it still happens. I have driven it problem free for several hours at highway speeds but when I get to the back roads it begins stalling again. When it stalls, it starts right up but will stall again as soon as I slow down or turn again. At a light I have to keep it revved to prevent it from stalling.
    I also have an intermittent highway driving problem where I lose most of my power--it won't stall but suddenly it won't go over 30 mph. I don't know if this is related to the other problem?
    Anyone have any ideas?
    thanks
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    njbeach, Looks like an idle prob, does ur car idle?
    May 2003
    When I first start it up, in general, it idles fine. Driving it is fine until I start to slow down. Then the engine cuts off entirely. I can re-start it with no problem, but if I'm still stopped (at a light) it won't maintain the idle unless I keep it revved.
    I used to have the same problem. What I did was use carb cleaner several times and blew all that shit out of there. I think I used two cans. Anyway, also be positive you have no vacuum leaks. Also, I had the mixture adjusted-- mine was LEAN. That might be your problem. Ever since then I havent had any problems.
    Jun 2002
    Edmonton, Alberta
    Yeah, carb cleaner is the first option. Remove the brass screen on top of carb, u can see 2 brass pipes pointing upwards at an angle (~1/4"), so called "inner (float bowl) vents". With engine at idle, spray a lot of cleaner in the pipes. Cleaner is mixed with gas in float bowl and will be sucked through the idle passages and hopefully clean it.
    If that doesnt work, u may have to remove carb top hat (6 screws) and remove the gunk deposited in float bowl.
    A common prob with 86-87 carb 3gs. When I had this prob, my gas filler pipe was rusted and dirt and dust made it through filters in carb bowl!
    The filler pipe is also on recall. I'd go get that taken care of too.
    May 2003
    86 LX 4 door
    Grand Junction, CO
    engine stalling
    I have an 86 Lx that had the same problem. I tried new fuel filters, gas treatments adjusting idle, pcv valve then finally i tried the fuel pump. I guess it was just barely starting to go out so it only did it every once in a while but now i haven't had any problems yet. I just put it in yesterday its only a 50 dollar part if u can handle that.
    Low And fast is the way I live
    May 2003
    Thank you all for your responses. I have already had the filler pipe replaced (yes, it had rusted out) as a Honda recall and had been wondering if crap from that had gotten into the tank. One detail I forgot to say is that when the car stalls as I turn or stop, it dies very abruptly, without warning.
    I'll look at the carb again and the fuel pump, too. Thanks again.
    Aug 2003
    89 Accord LX
    DC
    It sounds like I am having the same problem...but it's only happened a couple of times...so far. I'm teaching someone to drive stick, and for a couple of miles afterwards it stalls out when I stop or slow down. It seems as if the rpms drop a little too low, below 800 or so, and then it just chugs out and dies, but starts up again fine. The thing is, it only lasts for a couple of miles after he drives it (or tries to drive), then it's able to hold 1000 rpms at idle without a problem.
    We could just have one of us drive, but if there's a solution to this, it would be good.
  1. Engine keeps stalling mechanics can't figure it out
    By CreativilyNsane in forum 3geez Accords
    Last Post: 06-18-2012, 05:15 PM
  2. A/C and Stalling
    By jbthompson in forum 3geez Accords
    Last Post: 08-02-2010, 07:57 PM
  3. Replies: 21
    Last Post: 12-21-2005, 05:04 PM
  4. Help: weird hesitation/jerking of engine w/o stalling
    By lionel in forum Carburetor Tech
    Last Post: 07-14-2004, 08:25 PM
  5. stalling!
    By Neuspeed007 in forum Carburetor Tech
    Last Post: 12-05-2002, 08:55 PM
