Results 1 to 9 of 9
Thread: Efi Vacuum removal
    1990 Mitsubishi Eclipse GS-Turbo
    Honolulu, Hawaii
    Efi Vacuum removal
    Does anyone have a link to a how-to on this? I searched a couple subjects but only got carb stuff.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I don't think you can remove very many vacuum lines... are you looking to replace the lines or just dump the extra ones?
    I'm sure if Seans ECU get on the market you can get rid of the vacuum lines that way.
    Oct 2001
    87 Accord EX , 5spd , Manual
    EFI ?? and you want to remove vacuum lines !!! do you really have any ( comparing to carb ! )
    MIKE
    Honolulu, Hawaii
    looking to dump all the ones i dont really need.
    carotman's Avatar
    Montreal South Shore
    Well, you need all of them
    2 vacuums for the spark advance (you want those)
    1 vacuum for the charcoal canister
    2 vacuums for the IAB (you can disable it)
    1 vacuum for the EGR
    1 vacuum for the MAP sensor
    1 vacuum for the Cruise Control
    1 vacuum for the FPR
    That's about it.
    You can't really remove them. I know that Mike @ openloopmotorsports removed most of them but it affects the way the car reacts.
    You need at least the MAP sensor, the EGR lift sensor and the ignition advance
    I need these parts!
    Honolulu, Hawaii
    What is the charcoal canister, IAB and EGR?
    87 Lxi Hatch<-Blown Up!! 96 civic coupe
    Hot, Sweaty Florida
    Where is the MAP sensor located?? I heard that it is the little box with the little vaccunm lined out of it!! The new accords have them on the Throttle body???
    Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
    Nov 2002
    Ridin Dirty in New York
    its in the control box. The new accords do have them on the throttle body or on the intake manifold, most on the throttle body. IAB is intake Air bypass. You need almost all of them for the car to not have a serious loss in hp or torque and also so you dont have any driveability problems.
    Justin86's Avatar
    Medford, Oregon
    So I can get rid of the 2 vacuums for the IAB and the 1 vacum for the cruise control since I removed it, and still not run into any problems.
  1. vacuum removal
    By 2slo in forum Carburetor Tech
    Last Post: 10-06-2009, 09:23 PM
  2. Vacuum Removal
    By clark_486 in forum Carburetor Tech
    Last Post: 03-21-2009, 01:23 PM
  3. vacuum removal
    By crucial in forum Carburetor Tech
    Last Post: 11-21-2007, 10:12 AM
  4. EFI vacuum removal??
    By gfrg88 in forum Performance
    Last Post: 08-21-2006, 10:25 PM
  5. ? on vacuum removal
    By iron in forum Carburetor Tech
    Last Post: 07-15-2004, 03:40 AM
