Results 1 to 8 of 8
Thread: Annoying Beeping
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Angry Annoying Beeping
    Whenever someone gets out the passenger side with the car running, it's starts to usual beeping to let me know the door is open. The only problem is that after the door is shut it doesn't stop. I don't why the hell it does that. The only way to get it to stop is to turn the car off and then start it again. It's annoying and a pain in the ass. Does anyone have any ideas?
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    cut the wire for the beeper thingy, its under the dash were the ash tray is.
    Oct 2001
    87 Accord EX , 5spd , Manual
    i don't have that beeb !??
    MIKE
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    just cut the wire that goes to the beeper and wire it to some C4, but make sure after the passenger gets out that you run!
    -Aaron-
    LX User Night Rida's Avatar
    1988 Honda Accord Lxi Coupe
    Savannah, GA
    Real help 4 u!
    ok man, on the door jam there is a L shaped switch that goes back and forth when the door closes and opens. Its next to the lock mechanism, look at it and make sure it is not broken or something, thats all I can think of.
    Night Rida:badass:
    LXi User Jerren's Avatar
    Jul 2001
    1991 H23 powered Accord EX Wagon , Turbo 91 Honda CRX, and 96 Blazer LT
    St. Louis
    lmao, that has to suck for your car to keep beeping after the door is closed . i bet people think your car is going to blow up. you should take it to car-x or somewhere. the mechanic would think you set a car bomb in your car.
    shepherd79's Avatar
    Falling Waters, WV USA
    don't cut the wires.
    if you unplug it, you will loose the side markes (next to headlights).
    this is what i did.
    took it out, i think it is like 2 bolts.
    try to destroy the speaker. don't destroy the board.
    it doesn't beeb for me, and it better not to.
    10/Honda/Ridgeline
    NJ
    I gues its diff for the coupes cause for us sedan guys, we dont get the beep cause the seat belt is not on the door. so anyways. remove the plastic panel on the door pillar next to the seat and u will find a hole near the place where the L shaped door thingie. just try to unplug it and u should be set.
  1. beeping thing
    By rfiks in forum 3geez Accords
    Last Post: 10-31-2009, 06:43 AM
  2. Annoying Vibration
    By maxsoccerplayer in forum Carburetor Tech
    Last Post: 03-20-2008, 03:29 PM
  3. Reverse beeping noise?
    By Cancer in forum 3geez Accords
    Last Post: 06-13-2006, 03:51 PM
  4. my car is annoying in the morning
    By chanyeehon in forum Carburetor Tech
    Last Post: 10-23-2003, 07:05 PM
  5. very annoying sound
    By BLck89accord in forum 3geez Accords
    Last Post: 02-15-2003, 07:22 PM
