Results 1 to 13 of 13
Thread: 18 , 20 , 22 degrees ignition timing ?
    Oct 2001
    87 Accord EX , 5spd , Manual
    hi guys !
    want your advice on this !
    what would be the best ignition timing setting ! it 's getting hot around here 30 >>> 40 'C !
    i am running 18 now !
    should i change to 20 or 22 degrees ! ?
    if i change to 20 or 22 will increase the RPM kick or decrease it !
    i run octane 90 fuel !
    BTW i am carbed 5spd manual and fully stock ! !
    thanx a lot guys !
    MIKE
    1988 Accord LXi
    Connecticut
    Gee Mike my service manual says 24 degrees (BTDC) for manual 49ST carbureted engine at 800 rpm (the red mark). No allowance is made for ambient temperature.
    Bill
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    whats the stock ignition timing on a 88 accord LX carbed with automatic trans??
    thanx
    Oct 2001
    i have an A20A2 engine !
    anyway here is a page from the service manual on all models !
    it says 20 +_ 2 ???? so where should i adjust it at ??
    MIKE
    1988 Accord LXi
    Connecticut
    This is bizarre. How do I include a photo? My 88 Service Manual is the second edition 1/88 second print 11/88. Under Specs 3-9, Section 24 Engine Electrical and page 24-7 it lists following measurements for ignition timing all at idling (MT 800, Automatic 730 rpm),
    carbureted engine manual 49ST 24+/-2 degrees BTDC, CAL 20+/-2 automatic transmission all models 15 +/- 2 degrees BTDC
    Fuel Injected engine all models 15 +/- 2 degrees
    All are indicated by a Red Mark.
    If I were you I would look at the label on the front hood to confirm. Mine clearly states 15 degrees (I have LXi). My label is red with some reference to Catalytic Converter then it lists various specifications eg. idle speed.
    Bill
    Oct 2001
    Bill > your service manual is for american cars ( i think ) with A20A1 engines ! but i didn't know it differs that much !
    anyway i 'll go and set at 20 !
    MIKE
    Oct 2001
    any opinions guys ! ?
    MIKE
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    I always set my timing on red mark i|i on the drive plate (AT). The decal under the hood says the advance is ~15*. So what's wrong with that?
    Where is the BS engine in the pic ? So my model could be KQ ?
    Oct 2001
    i only have one mark on my flywheel ! ??
    MIKE
    1988 Accord LXi
    Connecticut
    Sorry about the misunderstanding. I guess I should have realized you were in a warmer climate with the 30-40 degree description. I was going to ask about EX since in the U.S. there was only DX, LX, Lxi, Sei.
    Bill
    Oct 2001
    man this degrees do make a difference ! i have set it at 20 degrees ! and it pinged ( which means how shitty is teh gas that sold here though it's octance 90 ) when i floored it ! so i set it back a bit say 19 >19 .5 ! and man the car was really choked up before ! not i really restroed my power !
    and i also fixed the hard kick thing problem that was in this thread !
    http://209.151.81.66/showthread.php?...0&pagenumber=2
    thanx a lot guys for all the help !
    MIKE
    Jan 2003
    1994 Honda Accord EX
    Ottawa, IL
    I also get that kick too -- I call it my Pre-TEC
    I have to adjust my timing to get it to have constant power?
    Oct 2001
    you really can't imagine the kick that i had ! and i really had shity power before that ! as long as you have good power i wouldn't mess with it !
    MIKE
  1. need help with ignition timing
    By fijisac in forum 3geez Accords
    Last Post: 09-26-2009, 09:01 PM
  2. Ignition Timing Q
    By visionguru in forum 3geez Accords
    Last Post: 09-03-2006, 08:45 PM
  3. timing retarded 12 degrees
    By johnwc723 in forum 3geez Accords
    Last Post: 02-21-2004, 06:32 PM
  4. Ignition timing
    Last Post: 07-12-2002, 03:14 PM
  5. Ignition Timing. 88 LXI
    By flexsource in forum 3geez Accords
    Last Post: 05-10-2002, 12:10 PM
