What should be level of oil be? I'm talking about on the stick. I think the mechanic overfilled it.
There are two dots on your stick. The oil should not be above the upper dot.
My mechanic overfilled my oil by almost one liter. (As I found once I drained the excess). Instead of just opening the drain bolt (didn't have a way of lifting the car) I chose to syphon the oil out. Seeing how high the level was I decided against starting the engine again and just proceeded to lower a rubber hose of appropriate diameter through the dipstick guide into the oil pan. After I got the end of the hose in the oil I simply used the old gravity trick and syphoned the excess out. Beware though that this method takes a lot of time because the internal tube diameter is small and the oil is relatively thick. If the oil level is slightly above the full mark it may not cause damage, but if it is excessive, the excess pressure may press out or otherwise damage the oil seals. The amount of oil it takes to raise the level from the bottom hole to the top hole is 1 qt. You can guesstimate the amount of excess oil based on this volume and decide how you want to remove it from the engine.
Hope you find this helpful.
3axap.
our cars are supposed to take 3.2 quarts or something right? i always put in 4 and never have problems.
The "official" amount in quarts is 3.7. I put in three quarts and then about 20 ounces of the fourth quart. I doubt that four quarts is overdoing it enough to make any difference. In my case, before I got the oil pan gaskte replaced, I would need the excess along with more to keep the thing full of oil.
For me 4 quarts raises it exacly to the top level
4 quarts exactly puts it about 1mm above the top dot, which is just fine. That's after I start it and let the filter fill up
-Jared
when i change my oil i pour some oil into the filter before it's even on the car. fill it just a little and roll it around so that everything you pour in gets absorbed into the paper and at the same time lubricate the rubber ring on the filter. it's just a little thing i do each time, maybe more for piece of mind. but when i put the filter in it's not dry so that's kind of nice.Originally posted by Jareds 89 LX-i
Thats how it should be done, lube the ring seal and fill up most you can, but its sideways nature makes filling it up impossible. Just a little is fine, the lack of oil pressure is min. If you want a even piece of mind, just let the engine crank, but not start, for 10 sec., to build oil pressure by filling up the filter. But i think thats over kill.Originally posted by Grant2k
Rooz
here we go again !
READ CAREFULLY >
OVERFILLING THE OIL WON'T RESULT IN IMMEDIATE PROBLEMS , but it will result in damaging your oil pump , engine oil seals !
hope this clears things up !
MIKE
drastically overfilling, yes, but putting in 4 quarts rather than 3.7, no.Originally posted by ACCORD EX
here we go again !
READ CAREFULLY >
MIKE
i heard this story that happened one day when i was not working. a guy with some little car like a Geo or something came in and bought some oil because he thought his car was low. he bought like 3 quarts and put them all in and then he came back and bought more and continued to fill his car until he could see the oil from THE TOP OF THE VALVE COVER rather than looking at the dipstick. so he started his car right in front of the store, smoke came out everywhere, there was oil all over the parking lot and he didn't drive home that day.
:lol :lol :lol what a dumbass :lol :lol :lol
-Harvey
ok i was wondering about that too. they have told me 4 quarts before, but i knew it was a tad bit under that. im gonna need to change my oil soon. as well as the tranny fluid, and i might as well put in some new radiator fluid. i love valvoline oil, but i may use some royal purple. this guys shop i know sells it. he uses it in his racing turbo 5.0 mustang, so that stuff must be pretty good.
A kid that I used to work with had an older Jetta that leaked oil. Well, he though that it was low, so he put like 2 quarts in it. Started driving and smoke and oil started commin out everywhere. Next day I check the oil and im like holy crap. Drained 2 quarts out, start it up, and it runs fine again lol.
tim
