OK, here's a question for the tech heads on the board...... Our stock injectors flow at 240cc, what happens when you upgrade to a 310cc injector??? I know that you have increased the flow rate but can you control it by adding a Fuel Pressure Regulator(FPR)??? What I'm getting at is that when you run your stock injectors and increase the fuel pressure, you're adding more fuel to the mix so I'm trying to figure out what's the difference between the higher flow rate injectors and just increasing the fuel pressure???
