Results 1 to 25 of 25
Thread: how to get compressor clutch out ???
    Oct 2001
    87 Accord EX , 5spd , Manual
    Angry how to get compressor clutch out ???
    hello everybody ! as many if you know i replaced my compressor ( with a bad clutch coil ) with another one !
    now i am messing with the old one to fix it and sell it !
    any way i have a nippon denso ( look at the pic below ) i got teh 12 mm nut holding the clutch ! now the SERVICE MANUAL says " use a clutch removal tool to get teh clutch out ! ???? " even if i can get this too ( which i can't ) how the hell would it work !
    look below to see what i mean !
    Oct 2001
    here is teh pic from teh service manual ! it says thread teh clutch removal tool to the plate !! ??????????????????????????? no threads are there !
    MIKE
    Feb 2003
    87 accord lxi
    roc, ny
    just buy my compressor, its cheap
    SiR's Avatar
    87 Accord LX
    Fort Lauderdale, Florida
    Thats exaclty is wrong with my old ND compressor. Maybe I should do the camething your doing and sell it. Post when you find a way to pul the clutch out without the remover tool. I'll give my old one a look sometime soon.
    Rooz
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    the removal tool screws into the hole where the nut goes, maybe try a 3 leg gear puller
    Oct 2001
    so Pete you are saying that the clutch plate is threaded too ! ?
    i tried a 3 leg gear puller ! no enough clearance for the legs to get in ! ( .7 mm ) ??
    any other ideas guys ! pleeeeeease !
    MIKE
    Jun 2002
    yeh, check the inner edge of the hole where the nut is,....you should find that there's a thread in it,....if you can get a bit of threaded pipe to fit,then weld a nut onto pipe with bolt to fit,you'll have yourself a clutch removal tool
    Oct 2001
    well Pete ! you read my mind ! i was thinking of this pipe thing too ! thanx for the backing me up !
    MIKE
    Jun 2002
    :super: :smokin:
    my nippon burned up too. I thought it was the better one cuz the pump had more cylinders but it really crapped out fast.
    oh yea I'm pretty sure i got out the clutch w/out any special tool
    Oct 2001
    how did you that ?
    MIKE
    Aug 2001
    1988 Accord LX-i (RIP)
    ND's are the really crappy ones right? compared to the Sanden compressors?
    Did any of our cars come with the Sanden compressors stock, or was that an aftermarket deal with the whole r-134a conversion issue?
    Accord EX, please inform us on what you find out inside the compressor (clutch, and coil)... i am interested in fixing mine as well.
    This useless space for sale, please inquire at the front desk.
    Oct 2001
    well i promise you guys once i get the damn clutch out i 'll photoshoot everything ! ( i never seen pics of that )
    and NO ! KEHIN are the real crappy ones ! ND 's are much better ! all i know is that our cars came stock with ND's and Kehien !
    MIKE
    Oct 2001
    hi everybody ! i went to a machinery shop ( really nice guys ) today and mad my self a clutch removal tool !
    look below ! ( can't wait to use it )
    Jun 2002
    :super:
    Oct 2001
    thanx Pete !
    MIKE
    Oct 2001
    finally got it out !
    woooooooooooooooooooohooooooooooooooooooo !
    a how to in a few days !
    still didn't figure out how to fix teh coil it self instead of replacing !
    MIKE
    Jun 2002
    which coil mike?Ignition?
    I have the pics in the garage computer gotta find them
    Oct 2001
    no i mean teh stator coil for the compressor the one that pulls teh clutch to the pulley to turn on the compressor ! this coil has to have a resistance of 3.4 ohms mine doesn't have a thing at all ! that's why i replaced my compressor ! so if you get the coil out you can buy an OEM replacement from majestic honda for 50 $ which is much cheaper a compressor ! and it's pretty common problem to compressors !
    MIKE
    Oct 2001
    well here are the pics but i'll organize them and write a how to as soon as possible ! can you guys think of a way to get the coil out of it's casing ! any help is appreciated !
    THE TOOL FOR THE CLUTCH
    CLUTCH PLATE
    PULLEY ( PRESSURE PLATE )
    MIKE
    Oct 2001
    STATOR COIL
    AFTER REMOVAL
    MIKE
    Jun 2002
    MIKE
    yeh, i realised after i wrote the post,... ....good work by the way... ...does the new coil not come with the housing as well?
    Oct 2001
    the new coil comes with everything ! but i am looking for a way to fix this one !
    not easy to find a honda parts around here !
    MIKE
  1. Looking for a clutch for nippondenso compressor
    Last Post: 07-09-2012, 05:49 AM
  2. Where is the A/C compressor clutch relay?
    By nfs480 in forum 3geez Accords
    Last Post: 05-20-2008, 07:59 PM
  3. 89 prelude clutch pedal or cLuTcH problem!?!
    By myaccord7 in forum Classic Preludes
    Last Post: 10-14-2006, 10:45 AM
  4. Replies: 5
    Last Post: 12-13-2005, 02:33 AM
  5. Compressor Clutch Problem
    By SiR in forum 3geez Accords
    Last Post: 10-16-2002, 06:33 PM
