Results 1 to 6 of 6
Thread: Valve cover leak
    89cordlx's Avatar
    Black 1989 LX-I Coupe and 2000 EX V6 coupe
    Westerville, Ohio
    Valve cover leak
    Ok, I have a small oil leak from the far left bolt that holds the valve cover on, and another small leak from the middle part of the gasket near the front. is there a sealant that goes on new gaskets or something? and how to I fix the leak near the bolt?
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Get a new valve cover gasket and grommets.
    That should solve your problem.
    Oct 2001
    87 Accord EX , 5spd , Manual
    if you can't get a valve over gasket use a high tempreture sillicone ( special type ) , i used it no problem ! ( i couldn't find the gasket !
    MIKE
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    If the gasket is in good condition (still rubbery and flexible) then just get this stuff at napa or any parts store call Gasket Sealer. Then what you do is put that around the metal and the put the gasket in the grooves of the valve cover and place it back on the head. The gasket sealer goes between the head and the rubber gasket and then the valve cover goes over everything. (figured it might be confusing and people might get mixed up)
    SEi User adams86lxi's Avatar
    86 Honda Accord LXI 5speed
    so cal.
    I had the same problem my dad went to the honda dealer and picked me up a new valve cover gasket yesterday and the grommets are on order. I dont remember how much it was but real cheap!! I look up the price later after i find the receipt, But I would just get a whole new gasket.
    Oct 2001
    GASKET SEALER !! that's the name i was looking for !
    MIKE
  1. Replies: 8
    Last Post: 10-03-2007, 12:18 AM
  2. Valve Cover - Oil Leak
    By PsychoPaul in forum 3geez Accords
    Last Post: 03-07-2004, 05:03 PM
  3. Valve cover oil leak
    By agelder in forum 3geez Accords
    Last Post: 03-30-2003, 04:33 AM
  4. Oil leak--Valve cover gasket or PCV?
    By 1989 DX R in forum 3geez Accords
    Last Post: 11-04-2002, 06:41 PM
  5. Valve cover
    By TeKKnoTeKK in forum 3geez Accords
    Last Post: 05-13-2002, 11:53 AM
