Results 1 to 13 of 13
Thread: Signals???!!!!
    May 2003
    88/honda/accordlx
    Lightbulb Signals???!!!!
    hello people, the signal blinker on the cluster panel do not go on...neither do the lights on the outside..what is the problem..i hate driving without signals and it's dangerous too..thanks
    SiR's Avatar
    Jul 2002
    87 Accord LX
    Fort Lauderdale, Florida
    Re: Signals???!!!!
    Sounds like your combination switch took a shit. Take it out and see if cleaning the contacts work. You might have to get another one, junkyard time!
    Rooz
    '88 Accord Lx-i
    Tigard, OR
    Check the fuses, or the relay is out, but it sounds like the fuse if nothing works...
    - 01 Ford Ranger 4x4
    Flip down LCD screen and DVD player, 8000k HID's, Westin light bar w/ PIAA 520's, Custom Flowmaster cat-back.
    2.0Si User Blue Impact's Avatar
    93 Integra LS-S
    Oroville, CA (it's on some maps)
    Either the fuse or the combo switch. Most likely, I would say it's the fuse, unless you really know your combo switch is messed up.
    Quote Originally Posted by k-roy
    Street racing is for idiots.
    Nov 2000
    Just come to Dallas/Fort Worth. Nobody here ever uses their signals so you won't have to fix the car.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    :lol
    It sure seems like that. Check the fuses and if they're ok then we'll help you through the job so you won't have to spend $200 for a new switch and $200 for labor from a shop. I did mine in a hour only knowing a little bit of what to do.
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    :lol
    May 2003
    88/honda/accordlx
    I checked the fuses and they are fine. Where is the combo switch located and how do i fix it..can i get some step by step instructions? by the way i have another accord i can get parts out of..thanks again.
    SiR's Avatar
    Jul 2002
    87 Accord LX
    Cool, you got another parts car. The Combo switch is the two levers for the headlights, turn signal, and wipers. Both levers are one assy. You have to take the wheel off, top and buttom covers on the steering colum. I never took the switch out, but it looks easy enough. The wheel comes out by prying out the "H" in the center, and take off the nut that hold the wheel to the shaft.
    Rooz
    89 LXI
    Maryland
    Now here's where the hard part comes in but you'll be able to do it...... Before you remove the steering wheel, make sure your wheels are as straight as you can get them because you don't want to have to play with lining up your wheels with the steering wheel at the end of all of this....... Since the steering wheel and the covers are off by now and remember you MUST also take off the medium sized cover that's right under the steering column as well to expose all of the wires in that area, you should see 4 screws that hold on a cover for the combo switch....... Once the screws are out, look directly at the combo switch and you should see 2 screws that hold the combo switch in place but in order to get at them you're going to have to move each lever accordingly up or down......
    Now, when you take these scews out don't take the combo switch off the steering column yet........ The combo switch has a harness with 3 connectors at the end, trace the harness down the steering column until you come to their ends....... It's going to be tight in there because of all of the other wires in that area but if you have small hands you should be ok..... Disconnect the 3 connectors, remove the harness and remove the combo switch from the steering column...... Installation of new combo switch is in reverse order...... I would recommend going to the salvage yard for this part because there you should get it for no more than $60......... Have fun, I know I did.........:lol
    LXi User 88LX-iSedan's Avatar
    1992 Infinity Q45 - 1996 Nissan 240SX
    Kingsport,TN
    ..There is nothing hard to replacing the combo switch, I done it myself so i know, It prolly didnt even take 5 or 10 mins. When i bought the switch from the junk yard along with both headlight housings, Side markers and hood it came up to just a bit over $200. ...I can't believe a shop would charge $200 just to install the switch, That's ridiculous!
    89 LXI
    Maryland
    To a newbie, it won't be the easiest job in the world but to someone who is familiar with their car than, sure, it's not difficult....... And trust me, a newbie will take more than 5 to minutes to change a combo switch.......
    93 Integra LS-S
    I bought my combo switch from a junkyard (Pick N Pull) for under $20 and took me roughly 20 minutes to take my old one out and replace it.
  1. Turn Signals
    By Fuzy Navel in forum Interior & Exterior Care
    Last Post: 03-02-2007, 04:20 PM
  2. Turn signals
    By Nate2310 in forum 3geez Accords
    Last Post: 01-20-2004, 06:17 PM
  3. Signals???!!!!
    By rleyba in forum Classic Honda Community Chat
    Last Post: 05-18-2003, 08:30 AM
  4. alarm signals??????????
    By disfunktional8o8 in forum 3geez Accords
    Last Post: 03-15-2003, 09:00 AM
  5. No turn signals!
    By GhEtTo 88 HB DX 5spd in forum Classic Honda Community Chat
    Last Post: 11-03-2002, 02:16 PM
