Results 1 to 3 of 3
Thread: Sway bar bushings
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    Sway bar bushings
    My sway bar bushings are in pretty bad shape. Last time I looked they were all rotted away. But what I want to know is if I replace just the bushings will this have any affect on the handling capability of my car?? Also how hard is it to replace the FROnt sway bar bushings? It looks pretty simple just take the wheel off and it looks like the bolt on there has two nuts one on the top and one on the bottom. Iam thinking just unbolt those and either replace the bushings or replace the whole bolt too. any ideas guys??????
    R.I.P. Died on 7/2/03......
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    It helps a little with handling, especially going thru a corner, but not substantially. If you drive your car alot, then you can tell the difference. Those bolts might be stuck in there, I broke one side. There are also 2 more bushings that you might want to check on the sway bar.
    You might want to get some polyurethane ones for a "tigher" feel
    shepherd79's Avatar
    Falling Waters, WV USA
    it is very easy to do. i changed my front bushings to Polyurethane bushings. i bought two sets long time ago and i still have one left. If you want it, $15+ shipping and they are yours.
  1. Sway Bar Bushings
    By bank2me in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-28-2008, 12:14 AM
  2. sway bar bushings
    By alboy86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-25-2007, 10:09 PM
  3. Polyurethane bushings for sway bar
    By jeremiah0678 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-12-2005, 09:31 PM
  4. could sway bar bushings cause this noise?
    By 88vert in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-06-2005, 03:32 AM
  5. sway bar bushings
    By Tim Yoak in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-08-2003, 12:39 PM
