Results 1 to 4 of 4
Thread: Fixed PS leak.
    88 Accord
    Fixed PS leak.
    From what I diagnosed early, it appeared the PS was leaking from the control block to where it bolts to the rack.
    I picked up a new seal that seals this block to the rack. After taking off two bolts and pulling this unit down, it appeared there was gasket material between the two.
    Honda doesn't have any record or show this gasket at all.
    I replaced the large seal, inspected the two small port seals, and ran a bead of RTV around the control block.
    Bolted it back up, not expecting the leak to be fixed, as I could never get the two units completely dry of PS fluid.
    However, it did work! :super:
    No PS is a pain in the city. Good for track racing mind you...
    Cam G.
    94 Z28, 355 ci, M6
    88 Honda Accord LX, A4
    1989 Accord LX Coupe
    Vancouver, BC
    I went down to Honda today to try and pick up the part and had no luck. Did you pick yours up at a parts store.....do you have part numbers??? I called a parts store here called Lordco and they weren't very helpful; what should I ask for? Thanks for your help!!
    15" wheels with Toyo Proxes FZ4 205/50/R15
    Eibach Sportline 1.5" drop
    JVC KD-SX990, Sony 6x9's, 4" JBL, 10" MTX ThunderPro, 350w Kenwood, 70w Sony
    88 Accord
    What part?
    This gasket I had to make out of RTV.... Honda doesn't list it.
    It is there though!
    Cam G.
    94 Z28, 355 ci, M6
    Vancouver, BC
    I see, but what about the seals you mentioned in the first post? You said you replaced the large seal and ran a bead of RTV....sorry to be so picky, just want to minimize the time with power steering fluid all over me. Thanks again
  1. Fixed Leak, Undercoating, and Carpet Cleaning
    Last Post: 08-08-2012, 08:52 PM
  2. Oil leak Found.. now an even worse oil leak....
    By Christofur in forum 2geez Tech & Performance
    Last Post: 03-11-2011, 08:46 PM
  3. Replies: 9
    Last Post: 12-27-2005, 01:21 PM
  4. i fixed some of my car :D
    By A18A in forum 3geez Accords
    Last Post: 11-23-2005, 11:33 AM
  5. Fixed my car
    By RobT5580 in forum 3geez Accords
    Last Post: 01-17-2003, 01:08 PM
