Results 1 to 6 of 6
Thread: Nippon-DENSO Compressor Stator Coil Replacement :
    Oct 2001
    87 Accord EX , 5spd , Manual
    DEFINITION:
    Stator coil is a device that converts electricity and converts it to a magentic force , so it once you turn your AC on it pull the compressor clutch to the turning pulley (pressure plate ) and the compressor starts spinning and compressing the air .
    TESTING :
    before attemping to get the startor coil out , which will result in getting your compressor out , unhooking the FREON lines and loosing it , you can test your clutch by finding the coil harness which will be near the raditor driver's side just above the compressor , test it with a multimeter ( car is off ) it should give a resistance of 3.2 > 3.5 ohms , other wise it needs replacement !
    Another test is turn on your ignition , ask a friend to turn on AC and see if the clutch has moved ( engaged ) , if it does > everything is fine , doesn't > replace the coil .
    TOOLS NEEDED ( tools needed in getting the compressor out not included ) :
    1. 12mm socket
    2. Flat Head screw driver .
    3. Clutch Removeal tool .
    4. 3 Jaws pullaer ( or use a hammer )
    5. straight Nose Circlip pilars .
    6. a cross head screw driver
    7. New Stator coil ( PART # > 38924-PH1-N01 STATOR COIL SET $50 > 60 $ )
    PROCEDURE :
    1. unbolt the 12 mm nut using a 12mm socket while holding the clutch plate ( to keep it from turning which is a very hard job )
    2. once you get the nut out get the washer out ( don't lose it !! )
    3. use a special tool to get the clutch out ( shown below ) you can do a custom one or buy one , or just got to any AC shop and ask them to get the clutch out ! ( i tried everything believe me )
    4. after you get the clutch out ( don't lose the second washer ) ( the most difficult part of the process ) get the circlip out using the straight nose circlip pilars
    CLUTCH PLATE
    Oct 2001
    5. use a 3 jaws puller and pull out the pressure plate ( pulley ) ( i used a hammer )
    PULLEY ( PRESSURE PLATE )
    6. use the same pilars again to get the circlip that holds the coil !
    7. get the coil out and unscrew it's ground wire that is attached to the casing using a screw driver !
    STATOR COIL
    AFTER REMOVAL
    8. Replace coil ( haven't figured a way to fix it yet )
    9. installation is reverse the removal
    WARNING !!!! when cleaning don't use gas or any related products to clean the pressure plate ( pulley ) because it contains bearing which is oiled ( you can re-oil that again )
    Good luck !
    A how to on AC trouble shooting and compressor removal will be on in a month ( when i finish my term exams )
    Oct 2001
    this how to will be here for 3 days for any comments and them moved to the how to 's !
    MIKE
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    good job...i always like pics that shows a little tummy...:super:
    Oct 2001
    MIKE
    Oct 2001
    last call !
    MIKE
  1. Denso A/C compressor
    By carotman in forum 3geez Accords
    Last Post: 05-26-2007, 01:46 PM
  2. Replies: 2
    Last Post: 12-27-2004, 11:47 AM
  3. what compressor? Denso or Keihin?
    By POS carb in forum 3geez Accords
    Last Post: 08-11-2003, 12:45 PM
  4. denso ac compressor
    By Tref_LXI in forum 3geez Accords
    Last Post: 06-15-2003, 07:17 AM
  5. Replies: 0
    Last Post: 05-17-2003, 12:57 PM
