Results 1 to 12 of 12
Thread: car starting hard then stalls??
    DX User AD9SloAccrd's Avatar
    May 2003
    89 accord lx
    Bowling Green, OH
    Unhappy car starting hard then stalls??
    after i drive my car for a little bit and shut it off, say an hour later i go back out, my car starts a little hard and when it starts it stays on for a few seconds, then stalls out.... but then when i go to start it again it starts up fine and no problems after that
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    Flooded? like u havto open throttle to start it?
    Oct 2001
    87 Accord EX , 5spd , Manual
    what have you changed in your car ?
    MIKE
    May 2003
    89 accord lx
    Bowling Green, OH
    i haven't changed a thing on my car, but sometimes it won't start so i have to pump the gas pedal a little bit and then it will start up... sometimes it will stall and sometimes it won't
    Oct 2001
    tune up ! fuel filters , air filter , spark plugs , spark plug wires , check cap and rotor , engine oil , oil filter !
    MIKE
    May 2003
    89 accord lx
    Bowling Green, OH
    it doesn't make any sense.... i bought this car from a friend and it was his moms car. whenever anything was wrong they took it in right away found the problem and had it fixed. he has replaced so many things on the car within the past year such as: major tune-up, spark plugs, spark plug wires, distributer cap, oil change, air filter, fuel filter, new windshield (doesn't mean much about how the car runs), a new gas tank, and so much more. this guy took really good care of the car, he even had it rust proofed when he first bought it brand new, which helped a little, but you know how honda rust is...
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    well we're suggesting you check all the normal things on your car before we can progress to other possible problems.
    I mean we want to knock the simple things out of the way so we don't start suggesting more involved car repairs and you ending up doing the work for nothing.
    May 2003
    89 accord lx
    Bowling Green, OH
    today i had no problem starting it this morning, before and after school..... also i felt like a fricken jackass because i locked my keys in my car -->kick in face lol
    DX User scandalcat1's Avatar
    Jan 2003
    1988 Honda Accord LX, 1995 Nissan 240SX SE, 1995 Kia Sephia LS
    The throttle suggestion makes sense. But it can also be the fuel pump and/or relay. When the fuel pump starts giving, it becomes intermittent for a little bit before it stops pumping.
    If it is the relay, have it tested (not by SPARKS!). Make sure that nothing is shorted under the rug where the relay wires run to the back.
    And also as previously posted, check both fuel filters and also vacuum hoses for cracking and/or leaks
    "In silence, the word is sown. So that it may flower shouting, it goes quiet"
    Oct 2001
    carbed = no relay !
    MIKE
    Jan 2003
    ACCORD EX
    Hey Mr. Mike
    Here is the LINK:
    http://www3.autozone.com/servlet/UiB...3d800d0907.jsp
    AND HERE IS THE REST IF THE LINK DOES NOT WORK...
    In-Tank Fuel Pumps
    1.
    Turn the ignition OFF.
    2.
    On the Accord, remove the screws securing the underdash fuse box to its mount. Remove the fuel cut-off relay from the back of the fuse block and turn the block so you can see the relay mount. Use a jumper wire to connect the two left-most terminals of the relay mount (terminal 1 to terminal 2).
    3.
    On Preludes, remove the dashboard under cover; remove the fuel cut-off relay from the fuse block. Use a jumper wire to connect the top 2 terminals (terminals 1 and 2) of the relay mount.
    4.
    Disconnect the fuel line at the fuel filter in the engine compartment. Connect a pressure gauge to the fuel line.
    5.
    Turn the ignition key ON until pressure on the gauge stabilizes, then turn the key OFF.
    6.
    Pressure should be between 2.6-3.3 psi (18-22.7 kPa). If the pressure shown is below minimum, the pump must be replaced. If pressure is at least minimum, continue with the test.
    7.
    Remove the pressure gauge from the fuel line; hold the line in a quart container. Have an assistant turn the ignition switch ON for 60 seconds, then shut it OFF.
    8.
    Fuel flow in 60 seconds must be at least 25.7 oz. (760 cc).
    9.
    If fuel pump volume is below specification, the pump must be replaced.
    10.
    Remove the jumper wire at the fuse block. Reinstall the fuel cut-off relay. Reinstall the fuse block on its mount.
    any questions?
    Jan 2003
    And again...
    I guess assuming that some people on the board know which fuel pump relay (being the cutoff and common knowledge) on the LX Carb is the one I am talking about, I apologize and will never assume on this board again, only be clear, concise, consistent and best of all specific.
  1. Hard starting 89 LXi
    By old accord guy in forum 3geez Accords
    Last Post: 06-10-2011, 02:49 PM
  2. Almost Stalls and now starting problem-LXi
    By Creator in forum 3geez Accords
    Last Post: 05-26-2010, 04:39 AM
  3. Hard starting
    By LXi87Accord in forum EFI Tech
    Last Post: 05-20-2005, 04:10 PM
  4. Stalls after starting...???
    By GBs863drLxi in forum EFI Tech
    Last Post: 10-25-2004, 08:54 PM
  5. hard starting question 4G
    By vtec11 in forum 3geez Accords
    Last Post: 06-21-2002, 05:36 PM
