Results 1 to 2 of 2
Thread: 5 speed swap questions
    Nov 2002
    Ridin Dirty in New York
    Ok, questions for the 5 speed swap... First one is, when doing the swap, do you have to switch starters? In the honda factory manual it specifies that the bolts for the starters are different, but makes no other 5 speed vs AT differentation, does that mean i can use the AT starter with the 5 speed bolts? Also is it possible to use the AT axle shafts with the MT ? The MT is like .2 inches shorter (also in the honda factory manual) , i think that the inboard shaft (which is nothing like the outer ones) would take up the slack and id be fine to use the AT axles... anybody know if they work for sure?
    YK86's Avatar
    Oct 2000
    BC, Canada
    Have you seen the write up in the how-to thread?? Has all the info you need. Anyways, the AT starter and MT starter has different bolt holes (the holes won't line up with the wrong starter). The passenger side axle is the same but you need the MT driver's axle.
    www.b20accord.com
  1. 5 speed swap
    By skinner17 in forum Classic Honda Community Chat
    Last Post: 10-21-2009, 12:31 AM
  2. 5-speed swap
    By import racer in forum EFI Tech
    Last Post: 07-21-2008, 07:28 PM
  3. 5-speed swap questions
    By snoopyloopy in forum Performance
    Last Post: 12-24-2006, 11:21 AM
  4. is this possible after a 5 speed swap?
    Last Post: 09-27-2005, 07:36 PM
  5. SERIOUS: For those who have done a 5 speed swap.
    By BITESIZE in forum 3geez Accords
    Last Post: 06-30-2003, 02:02 PM
