Does anyone have any good recommendations for settings for autocrossing, just got my camber kit installed and not sure what to set it at.
If you don't care about tire wear for daily use I'd do about - 2.5 front and -1.5 or so in the rear. What is your current caster setting? A little toe-out also seems to help reduce understeer.
Mike
This is not a subject I've really committed myself to know allot about. However I do recall that a slight bit of negitive camber is beneficial, like -1.5 in the front and less in the rear (maybe none at all in the rear). A excellent place to post question like this is at www.sccaforums.comOriginally posted by dhcarss
Now I d
