I Have an 86 lx and sometimes it will die when comming to a stop. It has happend to me several times now but it also runs fine sometimes too. Any Ideas would be a big help
Low And fast is the way I live
Man I wish I could help. I have the same problem with my Lx. It does it at ramdom and really pisses me off. I belive it is a problem with carbs cause my truck has a weber carb on it and it does the same thing as my car.
If it's a fuel problem... it might be a dirty carb or filters...
if its an ignition problem it might be the distributor... or distributor wires...
It could also be a vacuum leak... most likely distributor advance vacuum, brake booster vacuum, or idle diaphragm vacuum. They all tap into Manifold vacuum... so a leak in one place will effect the rest.
also check the regular stuff like oil, radiator fluid, cap and rotor, and spark plugs.
My ex's old 86 LX had that problem I tryed using a thicker oil and it went away
Different oil? That would be a new one. I could try it out if it still does it after I get the EFI working.
I just put new NGK's in it and the Fuel filters are both brand new.
I put a bottle of Cheveron fuel system cleaner and now it is running fine. I could just be getting shitty gas all over town or something. I don't know Ill let you guys know what I come up with. Thanx for the ideas
its most likely a vacuum leak. actually I would bet money on it.
"thicker oil"? i almost hurt myself i laughed so hard...
Who need wenches when ya got a shiny set of wrenches?
Grease Monkey forever!!
When i had this problem bout 1year ago, it was a ..rusty fuel filler pipe. Found like 1/2 of fine mud in carb bowl. From time to time, it was getting into those fine idle passages, blocking them. Removed, rebuild the carb, cleaned fuel tank, replaced filler pipe (recall).
mine was doing this too and it turned out to be the pcv valve. it only did it sometimes. also it would idle really rough sometimes.its only like a two dollar part.
Mods:
32/36 weber dgev
accell super stock coil
vacuum lines removed
pacesetter header
carsound highflow cat.
biohazard racing muffler
delta 272 Cam
Rebuilt engine
