well my passenger side head light wont go down or up, i turn the thingy for the head light and it went down and up but wont do it when i switch the headlights on..... i think the motor is dead......
ne ideas?
ne ideas?
If it goes up when you use the switch but not when you turn the headlights on it's not the motor. There is more then likely a loose wire somewhere or the switch isn't working properly.
I think the dash cluster switch utilizes the motor as the turn signal/combo. switch does. I agree that the motor would not be the cause. I hope it's not the combination switch... I doubt it is if one headlight is functioning fine while one is not. HTH.Originally posted by HostileJava
swap your retractor relays and see if the other side works. If it does, then just replace the relay. if it still doesn't work it'll be the headlight retractor control unit....... odds are its the relay... if you want a wiring diagram just say so and I'll post it.
Also check fuse #6 & #7 under the dash as well as #11 & #14 just to be thorough.
CoAsTeR
88' Honda Accord LX
www.coastersride.cjb.net
Visit my website for pics and how-to's
check the crush bushings. without the headlights in ON position, the motor gets more power. that why they ask u to use the headlight flip up switch near your dimmer and read-defogger unit. Try that, see if it would go up or down. if it works, the motor is fine. it might be a shot in your clip. remove it and blow dry it or just have it open in the sun. also, check the bushings and spray some lubricant on it and see if they do anything.
ok ok, on my accord, the lights go up fine, but wont retract. i looked at the switch to leave the lights up, it seems to be fine, i even tried disconnecting the switch and then trying to turn the lights off. they of course, still will not retract. the only other thing i can think of is the relay. but, where is the retractor relay located? sorry for my ignorance.
-will
The lights will not retract if the switch is not working or not connected.
Also won't retract if something is in the path of the light causing the motor to freeze and not retract. When you try retracting it, listen closely to the light motor-- if you hear a click sound, then something is causing the light to stay up.
Gee, I interpreted the "thingy" to be the black cylinder near the headlight for manually raising and lowering the light not the interior switch. Please clarify. If I have read your question correctly, I would start by checking the fuse because you should not normally be able to turn the "thingy" with the electrical circuit complete.
Bill
there is nothing in the way of the light retracting, and the motor does not make an electrical hum. i tested the switches earlier today (found the downloadable manual pics), they are all fine. however, i cant find the retractor light relay, or any of the other relays associated with the lights retracting. if anyone know where they are let me know. i even tried retracting the lights manually and pulling the fuse, but the lights stayed down. im not sure what that means, oh well. thanks
-will
make sure everything is properly grounded. Most of the time when i have an electrical problem on my car, it is usually caused by a bad ground.
i'm having the same problem!!!! i've noticed that it only does it when the interior's cold tho, like at night after driving with the a/c on... it's not anything physically blocking the lights and the motors are fine. i don't believe it's the switches either, and it works fine when the interior's warm. when they stay up, i just open the windows and let some hot air in and in a minute or so they go down. i really think it's a bad relay somewhere... but WHERE THE HELL ARE THE RELAYS!?? will someone please enlighten me?Originally posted by RustyHo88
-will
1. stand on the front of the car with the hood popped up.
2. STick ur hand to the left of the radiator/condensor part and u will find two relays covered in some kinda rubber sheith.
3. These relays go bad (it went bad on my car) and would pop the lights up but wont let them go down. so swap em out with the ones from the junk and they should be alright or get em from a local honda retailer or dealer.
well, i was able to finally fix my retractor lights when i pulled EVERYTHING out that had to do with the retrator motor circuit. i pulled out the main control unit, the relays, the combo switch, and the instrument cluster, and i tested each individually, they all worked fine, except the instrument cluster switch. so i swapped that from my parts car, and now it works fine. the problem your describing could be that. the switch might be reacting to the temp of your interior. if it were a relay, chances are only one of your lights wouldnt work, because the chances that both your relays die at the same time is slim. so, check your combo switch, and the main control unit. hope this helps.
hey... both my headlights won't go up or down... I've checked the engines by connecting to a power source, they will go up and down just fine... I have also checked the relays, and the in dash switch... any suggestions??
87 hatch (stolen)
88 lxi 4dr, 5spd, threw a rod... in process of swapping engine from my 87 hatch (police recovered what was left of the car).
the fucker that sold me the 88 is lucky he lives 500 miles from me...
Faulty combo switch (the lever on the steering column that you turn the lights on with). If you're feeling handy, dismantle everything and clean the contacts (there is sort of a how-to about this if you search the board). Otherwise a new one is upwards of 300 dollars.
This is your problem most likely.
check the main retrator unit under the dash. when you say you "checked" those other things... did you test them usuing the instructions in the accord manual? if not, then download pauls manual.Originally Posted by modu03
http://www.pauldesign.ru/honda/shopmanual.html
So, the things to test are:
1. Retractor Motors (engine comp)
2. Retractor Relay's (engine comp)
3. Main Control Unit (driv. Panel)
4. Retractor Switch (right of steering wheel)
5. Combo Switch (left of steering wheel)
If you test all these using the instructions in the manual, and they are all in working condition, then check all your connections. Make sure all contact points and grounds are clean. if that doesnt work, its time to start pulling wire to see if somethings shorted or grounded... or make your own switch.
Oh yea... check your fuses too
