Results 1 to 2 of 2
Thread: inside lights will not come on on my dash
    88 Prelude Si with 4WS
    Cherokee County
    I was driving down the road and saw that I had no lights inside of my car (Dash Lights) and I thought it could be from when I unplugged the dingy thing under the dash in the middle. I saw that I had no parking lights on the outside either so I figured it would be that. I finally got it down to a fuse that is a 15A, I put some in there when my fog lights where on and it poped as soon as I turned on my interior lights. I decided to put another one in but with the fog lights not on, It worked until I closed the door of the car. Nate (87accordsterlx) told me that it is the fog lights and I want to be able to use them and have inside lights with my parking lights inside of my headlights that I just got a new color. Please someone tell me how to fix this problem so I can know what speed I am going at night. I can't see any of the gauges casue I took that light out that was inside of the cluster casue I like when I can just see the illumination of the numbers and other things inside of it.
    *Content exceeds signature guidelines*
    88 Prelude Si with 4 Wheel Steering and a JDM B20A
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Ya might want to check for shorts all around, and if you have your fog lights wired without a relay, that might be doing it too. When I lost my dash lights, I accidentally broke my glovebox light and shorted the contacts. Took me three days to track down that fuse... turned out to be the license plate light fuse (THANK GOD I didn't get pulled)
    -5150
    glorious!
  1. Dash lights
    By Lil Mike in forum 2geez Accords
    Last Post: 08-12-2009, 11:24 AM
  2. Dash, Dash lights, clock, turn signal all not working?
    By Josh89accord in forum 3geez Accords
    Last Post: 09-06-2008, 07:45 PM
  3. anyones brake lights also turn on your dash lights?
    Last Post: 03-07-2004, 01:31 AM
  4. Blinkers and Inside lights
    By c20v6turbo3rdgen in forum 3geez Accords
    Last Post: 06-30-2003, 08:17 AM
  5. Dash lights???
    By Nospeed in forum 3geez Accords
    Last Post: 11-10-2002, 11:44 AM
