Results 1 to 12 of 12
Thread: no park !!!
    May 2003
    1988 Accord LX
    Cape Breton, Canada
    Question no park !!!
    car = 88lx
    problem = car will not stay in park
    i try to put my car in park. but 9 out of 10- times it won't go..the car tries to jerk itself in motion.
    fix = ? (any input would be great)
    SEi User cdscowboy's Avatar
    Nov 2002
    90 Nissan 240sx coupe
    Corvallis, OR
    does it do it when you shut it off?
    LXi User 88LX-iSedan's Avatar
    1992 Infinity Q45 - 1996 Nissan 240SX
    Kingsport,TN
    Umm.. Are you pushing the brake in when you try to put it in "Park".
    May 2003
    1988 Accord LX
    Cape Breton, Canada
    cdscowboy: if i'm on a hill it'll roll and make a grinding sound like its slipping gear.
    88LX-iSedan : yes i have the brake pushed down
    Kingsport,TN
    (Im not an engine wizz, Im just trying to help.) Sounds like the trans is about to go, Have you checked the fluid?
    May 2003
    1988 Accord LX
    Cape Breton, Canada
    i hope not...i'll try adjusting the shift cable tomorow see if that'll help.
    tranny was already replaced with an 87 lx tranny last year.don't want to go through that again.
    All the more reason to get a rebuilt tranny off the bat so you dont ever have to deal with it again. When mine goes, I'll either get it rebuilt or sell the car.
    YK86's Avatar
    Oct 2000
    BC, Canada
    Try adjusting the shifter cable. It does go out of alignment sometimes. Make sure the fluid is genuine Honda. My old auto used to grind when I put it in park but when I switched to Honda atf, it went away and shifted much smoother.
    www.b20accord.com
    Nov 2002
    Corvallis, OR
    ^^^ Do what he said. Hopefully you don't have to get a new one. If you do, you may as well go for a 5-speed conversion!!
    May 2003
    1988 Accord LX
    Cape Breton, Canada
    i adjusted the shifter cable and it still does it (not as much though)....is there an adjustment besides the one in the shifter?
    transmission was acting real bad few moths ago, i change the tranny fluid (honda atf) and it ran much better...it still shifts a little high(4000) could this be related to my park problem? and how would i fix this
    YK86's Avatar
    Oct 2000
    BC, Canada
    Make sure the engine idle speed is not too high. If the tranny is shifting late, the throttle cable might need adjusting as well. Look in the how-to for info on that.
    www.b20accord.com
    Nfld, Canada
    no, my 88 does the same damn thing... grinds sometimes when you put it in P, othertimes P is the same as reverse... the tranny is fuxored (from towing). It also slips out of drive alot. I have to put it neutral and use the handbrake when I park it.
    WTB: 4th and 5th gen OEM headlights and corners in good shape. Even single lights.
    1995 Honda Accord EX-R | 1988 Honda Accord EX-i | 1987 Honda Accord LX (R.I.P.)
  1. my wipers do not park, what is wrong?
    By lamontlamont in forum 3geez Accords
    Last Post: 07-13-2007, 11:35 PM
  2. my wipers do not park, what is wrong?
    By lamontlamont in forum Classic Honda Community Chat
  3. Grinding from Park to Reverse
    By rwerber in forum 3geez Accords
    Last Post: 03-22-2007, 07:53 AM
  4. windshield wipers won't park
    By jayshonda in forum 3geez Accords
    Last Post: 02-21-2005, 01:44 AM
  5. Stuck in park
    By gundamevo in forum 3geez Accords
    Last Post: 11-19-2004, 02:45 PM
