See, the sideskirts cover the area needed to jack up the car... anyone else have a problem with this? Am I stuck having to use drive-on lifts for the rest of my days? What about suspension work!?
just raise up the whole front end or the whole rear end....instead of just having to raise up one wheel at a time. just stick your jack next to the hook on the crossmember in the front....ive never raised up just one wheel at atime before..
There's two ways to solve that problem. Either make a cut out so the jack will fit (you can't see under the car anyways) or just leave it hanging without screwing the underside to the rocker panels. Stands will fit both ways and I always jack my car on the toe hook in the front or the center piece in the back the arms bolt onto.
www.b20accord.com
