Results 1 to 3 of 3
Thread: lower control arm bracket problem
    1989 accord lxi
    are the ower control arm brackets from the accords all the same(ie, 86-89)
    if not which ones would work with an 89 lxi 4door
    by lower control arm bracket i mean the piece that rins from one lower control arm to the other in the front of the car and also supports the engine.
    thanks
    fussell
    10/Honda/Ridgeline
    NJ
    88 should work. but why take the risk, get a 89 one. the sedan and coupe they all use the same.
    accord HB ( metallic green)
    B.C Chilliwack
    Yes I believe the front lower control arms are all the same from 86-89
  1. Lower control arm/radius rod f n nightmare
    Last Post: 07-15-2011, 11:11 PM
  2. pulling lower control arm off....
    By racerx in forum 3geez Accords
    Last Post: 08-01-2004, 05:50 AM
  3. Lower control arm replacement
    By AZmike in forum 3geez Accords
    Last Post: 09-29-2003, 12:26 AM
  4. Lower control arm swap
    By POS carb in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-29-2003, 03:12 PM
  5. lower control arm problems...STILL
    By 89accordlxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-18-2002, 07:21 PM
