Results 1 to 6 of 6
Thread: dim headlight, any help?
    1988 Honda Accord DX Sedan
    San Bruno, CA
    my passenger side headlight is way brighter than my driver side. i switched the headlights and nothing was wrong with them. just that the driver side is dim. also, both headlights are the same have same wattage.
    i swapped the fuses by the steering wheel with the rear defroster and same thing. the thing i noticed is, when only the fuse for the R low beam is in, the passenger light is fine and driver side light does not light up. when only the fuse for the L low beam is in, both headlights light up, but both are dim.
    i've searched through previous threads, and the thing i came up with is to check the wires by the headlight and make sure that they aren't cracked or something? my combo switch is fine, right, since the headlights do light up? are there any more suggestions to help fix this problem?
    WA State
    make sure they are level. Sometimes when aimed wrong, one can look that way....
    San Bruno, CA
    i'm pretty sure the driver side is messed up. especially at far distances or from reflection of the car in front of me, it only looks like 1 headlight is working.
    Oct 2001
    87 Accord EX , 5spd , Manual
    i see a short somewhere !
    what if you turn on the highest beam with out turning any of the others ( flashing > holding the light lever towards you ) ??
    MIKE
    check your ground
    San Bruno, CA
    ok, found the problem. turns out one of the three wires running into the headlight was frayed. i guess from old age. i used some extra wire laying around and spliced it right in. headlight looks good now. just have to see it at night, but i think it is no longer dim.
    thanks for your help.
  1. Very Dim Headlight
    By lamontlamont in forum 3geez Accords
    Last Post: 02-01-2006, 01:33 PM
  2. Headlight help
    By whyterice in forum Interior & Exterior Care
    Last Post: 01-17-2004, 09:28 AM
  3. headlight
    By Chadroper in forum 3geez Accords
    Last Post: 11-11-2003, 02:04 PM
  4. Ack! Need Headlight Help!!!
    By 3G Jester in forum 3geez Accords
    Last Post: 09-09-2002, 09:59 PM
  5. Right Headlight Is Dim
    By ‹^› ‹(•¿•)› ‹^› in forum 3geez Accords
    Last Post: 09-04-2002, 03:09 PM
