How do I replace the 6x9's in the back? Do I have to remove the entire rear deck, or can I just remove those grilles on top of the rear deck? What do I gotta do?
all you have to do is disconnect the wirings in yourt trunk (the positive and negative) and then take the grills off and there wil probably be screws and the itll come out.........AND NO NOT THE DECK!!!!!!!1 LOLsilly newbies!
LOL
But ya, just remove the screws under the grill
Aaron
My spelling was never a streingth...
Actually, there are three nuts for each grill under the deck, in the trunk. You remove those and disconnect the wires. You lift the entire grille/speaker assembly out from inside the car. Then, you will see the screws that hold the fabric covers to the grilles. Once the fabric covers are removed you will be able to access the screws that hold the speakers to the grille frame.
A rather elegant design, actually.
^Be patient with the 3 nuts to get the speakers undone, mine were REALLY REALLY TIGHT. I almost thought i had to do something else first, but just get those 3 nuts off and you'll be good
if you cant go fast, go loud and sexy
