My engine light came on while driving today going 45mph. The engine wasnt overheating and oil i good so could low tranny fluid do this....Opinions welcome. Thanks
1988 Honda Accord Coupe LXi
(Stock)
Cut car on, engine light comes on, check ECU under drivers seat for blinking light, count how many blinks after the pause and either remember these codes https://www.3geez.com/showthread.php?s=&threadid=185 or print them out and this will tell you your problem........![]()
Sorry for a dumb question but does anyone have a pic of what the ECU looks like. Unfortunetly my cheap manual doesn't even talk about it. But it came with the car so oh well. Thanks.
(Stock)
I don't have a pict but I will try to help you locate it start by pulling on the handle to make your drivers seat tilt forward. Then look under the back you shold see a plastic flap that can be flipped down when you do that you will see an led that is what will blink.
Sorry, can't help you there but if you look under your drivers seat with a flashlight, it will be plastic that's shaped like a box with a little flap that you can open to see the bulb that flashes if you have the check engine light come on............![]()
Ahh ok actually under the drivers seat. Gotcha now. Wasn't sure if you had meant under the steering column or not. Gotcha now. Going to check when I get a break from work.
(Stock)
Blinks twice so I assume its the oxygen sensor
(Stock)
I got both of my o2 sensors from www.nopionline.com I got NTK same company that makes ngk plugs they were about 20 bucks each universal.
Thanks man I was just curious but whats the difference between the O.E. Replacement., All Mdls. and Universal Replacement., All Mdls. ThanksOriginally posted by 1988starter
(Stock)
to be spicific I used this part number
973+0267
