Results 1 to 16 of 16
Thread: small fan?
    87accordlxi's Avatar
    Oct 2000
    small fan?
    hey guys, the smaller fan to the right of the large cooling fan is for the a/c, right? Mine was making all sorts of ugly noises so i yanked it out. and my a/c doesnt work, so it doesnt cause a problem there.
    the regular cooling fan still clicks on and works fine. i was just wondering if i'm gonna need to go out and find an a/c fan before going on a 1400 mile round trip drive.
    - Joe
    if your car doesn't overheat when you idle then no problems.
    2.0Si User Grant2k's Avatar
    my a/c doesn't work either. could i wire the 2 fans together so that they both come on for cooling? or maybe put a switch on the a/c fan?
    that would be a bad idea, both fans are separatley relayed and i think seperatley fused also. I doubt if you didnt have the fan the ac wouldnt work
    my a/c doesn't work anyway. i mean could i wire the power wire for the small fan into the bigger one so that when the regular cooling fan turned on the small one turned on too? so that i had 2 cooling fans. as i think about it this would probably be a bad idea because that means if the fans turn on when the car is off that's 2 fans running off the battery. i think a switch inside the car may be best.
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Don't both fans already come on? Last time I looked at mine (a/c off, just kicked on for cooling), both were running. Only time I've seen only one running was the small one after you shut the car off. Maybe that's just mine though.
    I wouldn't wire them together cuz you'd probably either burn up the relay or keep blowing the fuse. Those fans take up a good chunk of juice! If it's working fine the way it is, just leave it.
    Joe... if the large fan is still kicking on and keeping it cool, then I wouldn't worry about it. Still make sure by letting it idle for awile and make sure it doesn't overheat (with our cars it takes quite awile for them to heat up!), but it shouldn't. I drove mine around for over 2 years with only the small fan working, and that was when it felt like it, LOL.
    -Jared
    Jun 2001
    88 lxi coupe
    gainesville, fl
    I don't know about other models, but on mine both fans help cool the engine. The ac fan (also) turns on when the coolant gets hotter than it should. Can't remember, but radiator fan turns on around 90degrees and the ac fan turn on around 110 (or something around those figures).
    Apr 2001
    Mills River, NC
    Uhh...should be closer to 190 degrees or around there. 90 degrees is like the air temp outside on a summer day, lol.
    -Jared
    Jun 2001
    88 lxi coupe
    gainesville, fl
    we use celcius
    we use celcius
    damn, and i always thought Florida was in America.
    2.0Si User Blue Impact's Avatar
    93 Integra LS-S
    Oroville, CA (it's on some maps)
    So what? Now the US has 49 states since FLorida broke off and became its own country?
    Quote Originally Posted by k-roy
    Street racing is for idiots.
    10/Honda/Ridgeline
    NJ
    jared is right. All carb cars have the two fans in parallel. The radiator fan spins, then so does the AC fan spin. They both come on at the same time. Its the Efi cars that have a sub cooling relay in the fuse box and an extra fuse for the AC fan to come and go on cause the radiator fan goes on for almost 15 mts after the car is shut down. This is done thru the Fan control relay under the passenger front seat on the efi models (all 4yrs).
    So jared is right, all carbs have both the fans go on at the same time. efi cars dont cause of the fan controller.
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Yeap...we're now using solely metric so that NASA can get things done easier and we now drive on the right lane
    you mean the left lane? hehehe
    Jun 2001
    88 lxi coupe
    gainesville, fl
    bah@!!
    chicago , il.
    my g/f dx must have one then cause when i drive her's i hear the fan's then under the seat i hear a ticking sound.
    is there any way to make them run cooler?
  1. Small photoshoot!
    By Hazwan in forum Classic Honda Pics & Videos
    Last Post: 04-11-2009, 07:44 AM
  2. small photoshoot...
    Last Post: 02-18-2009, 11:47 PM
  3. Some small videos
    Last Post: 03-07-2006, 05:42 PM
  4. Boxes too small?
    By FyreDaug in forum Interior & Exterior Care
    Last Post: 11-17-2005, 08:24 AM
  5. small can of NOS...
    By Jerren in forum Performance
    Last Post: 05-27-2002, 08:18 PM
