Results 1 to 11 of 11
Thread: gauges wont light up!
    2.0Si User ‹^› ‹(•¿•)› ‹^›'s Avatar
    1988 / Honda / Accord / LX-R
    nYc
    last night while I was driving my gauges turned off and so did ac panel lights..do u guys think is a fuse problem??/ every other light in the car turns on..
    nYc
    HELP PLEASE?????
    Gauge hELP.........The Lights wont turn on!!!!
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    Do your parking and marker lights go out as well? If so, you might have a bad multi-function/headlight switch on the steering column.
    nYc
    every other light goes on, except the gauges & ac panel!!
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    If that is the case, check your dash lighting dimmer switch. It is another one that tends to die on occasion. It is the middle of three switchs to the right of your instrument cluster.
    nYc
    check how??? i treid turning up and down, but nothing...when I activate my alarm the gauges flash....It happened last night while driving...sucks dude.. I just purchased indiglo gauges
    LXi User pearldrop's Avatar
    Feb 2001
    93 Prelude Si..shaved and bagged - 96 S10 bagged and bodydropped, 99 Suburban dropped 5/7 on 22s
    NW Wash.
    Check your taillights. The dash lights go out when the taillights go out so you know that they are out. If they are out then it is just a fuse.
    nYc
    i will check again tonight...but if I remember correctly all the lights worked....sucks dude!!!!!! spent my last lil bit of pocket change on insurance
    1988 Accord LXi hatchback
    Yeah a blown fuse would be my first guess. If you just installed your indiglos chances are you popped a fuse, maybe miswired it.
    nYc
    Ok!! I just checked.... When I turn on the headlights, only the headlights come on!! none of the taillights come on..only when i brake...i have nor installed the indiglos yet..hoping to do it this weekend!!!!!!!
    JEHOVA! YOU WHORE!!
    nYc
    PROBLEM FIXED
    IT WAS ONE OF THE FUSES......FEELS GOOD..!~
  1. seat belt chime and warning light wont turn off
    By kkirkup in forum 3geez Accords
    Last Post: 03-04-2016, 09:24 AM
  2. Car wont idle; battery light on...plz help!!
    By CA5_KMT_LX in forum Carburetor Tech
    Last Post: 09-09-2012, 11:44 AM
  3. dashboard wont light up...
    Last Post: 05-22-2006, 07:17 PM
  4. light wont pop up HELP ME :(
    By ZackieDarko in forum 3geez Accords
    Last Post: 02-13-2006, 10:47 AM
  5. instaled reverse glow gauges now speedo wont work
    By stolenracer in forum Interior & Exterior Care
    Last Post: 12-20-2003, 07:24 PM
