Results 1 to 6 of 6
Thread: help, engine maintenance light is on
    Question help, engine maintenance light is on
    My 91 Honda Accord Lx engine maintenance light is on.
    Is there anybody know how to deal with it? Somebody tell me go
    autozone to read the code. but there are no autozone around.
    Thanks in advance!!
    Oct 2001
    87 Accord EX , 5spd , Manual
    it looks be carb ( LX ) so there is no ECU to check !
    MIKE
    ohhh, mike.
    91 accord LX had EFI enigne.
    Go to any respectful garage and ask them if they can read the codes. make sure you ask them to show it to you. this way you will know what is the problem.
    Nfld, Canada
    no fool! read your owner's manual. it will tell you about the maintenance required "light". It is not a light at all, nor does it tell you that anything is wrong. It is just like your odometer numbers, it is a little wheel that turns as the miles go up. Instead of numbers, it has a green yellow and a red section. All it does is tell you that you are nearing the number of miles that is recommended by honda for you to return for regular scheduled maintenance. ie, it has been 30,000 miles or whatever since that counter was last reset. I assume you never reset it yourself, so I assume the dealer reset it. See that little key sized hole next to it? stick your key in there to reset it.
    WTB: 4th and 5th gen OEM headlights and corners in good shape. Even single lights.
    1995 Honda Accord EX-R | 1988 Honda Accord EX-i | 1987 Honda Accord LX (R.I.P.)
    Thanks
    I just push it back to green using the key. I wish everything is fine.
    Thank you!!
    Oct 2001
    Originally posted by shepherd79
    ohhh, mike.
    that's really ! thoes honda engineers !
    MIKE
  1. Maintenance questions
    By Invisigoth in forum 3geez Accords
    Last Post: 09-24-2007, 03:23 PM
  2. Battery Light + Check Engine Light
    By tedhodges in forum EFI Tech
    Last Post: 12-28-2006, 08:34 AM
  3. maintenance schedule
    By hkplayer in forum Classic Honda Community Chat
    Last Post: 07-28-2004, 01:29 PM
  4. maintenance for 88 lxi..
    By FishyMan in forum Performance
    Last Post: 07-27-2004, 06:49 PM
  5. 2003 Accord Maintenance Light
    By ssophab in forum 3geez Accords
    Last Post: 04-01-2004, 08:44 PM
