Results 1 to 20 of 20
Thread: C.V joint boot !
    Oct 2001
    87 Accord EX , 5spd , Manual
    C.V joint boot !
    sorry guys for making another thread ! but i need to do my boot this friday ! i have a carb car 5 spd manual and i am doing my driver's side axle ( the long one )
    i was looking at it today ! and i was wonder how would the new boot pass the whole axle to get the outer joint ! it's so fat in the middle ! has anybody did that !?
    this what i did in my other axle > get the shaft out > get teh inner joint out , slide both boots get the boots on !
    i am kinda scared to diassemble the outer joint , the service manual didn't mention a thing about that !
    thanx a lot !
    MIKE
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    I think the simple answer Mike is,...you can't.
    You need to knock the outer C.V off to change the boot
    Oct 2001
    did anybody actually try that !!??
    how would i assemble it !! will it hold ??
    MIKE
    well, according to haynes manual, you will have to remove the axel. Remove the inner joint and after that you should be able to remove the outter boot.
    good luck on that man.
    check paul's manual for more info.
    Oct 2001
    i checked all that ! but i am still not sure if teh boot will pass through the middle ! anybody actually try that ?
    thanx guys !
    MIKE
    it should. try lubricating with soap. it should help sliding.
    Oct 2001
    i'll sure try that !
    i checked the service manual , haynes manual , 88 > 91 CRX Manual , 91 Accord manual and they all say > DON'T TRY TO DIASSEMBLE THE OUTER JOINT ! ?
    MIKE
    LX User Trowa's Avatar
    May 2003
    86 Honda Accord EX-i
    Edmonton, AB, Canada
    c'mon dude, i did it 2 TIMES!!! it works fine, snap it out, clean and then snap it back in. I don't think that there's another way to do it for that axel, it's just TOO think to slide the boot on.
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Take off the outer joint. That's how I did it.
    Oct 2001
    i know that i am asking to many questions but i can't afford to ruin a 300 $ axle ( where i live )
    i attached a pic below with 2 marks ! ( not a 3gee axle )
    where should i hit to pop the joint out ! # 1 or 2 ?
    and will any of the ball bearings will fall ! ?
    any circlips to remove !
    sorry for bothering you guys !
    MIKE
    May 2003
    #1
    and no bearing should fall out =)
    and if they do ur in trouble LOL
    Jun 2001
    88 lxi coupe
    gainesville, fl
    There's a clip around the axle (inside 1) which is the difficult part when you try to pop it back in. Good luck.
    May 2003
    i don't know, never had a problem with that one...... maybe it's just me. LOL
    tighting the thingy that holds the boot, now that was a b*tch
    87 LX Accord
    Richmond, BC Cana-DUH heeehee
    get a good brass drift and hit the inner race (the part right on the axle shaft, the whole thing is retained by a c-clip, a good solid wack should pop it right off, but use a brass drift, a steel one could damage the race and that would be very bad). Once it is off, make a very small mark on the inner race, the cage and the cup, uses those as a marker so you put it back together correctly, the bearings in there don't have to go back in the same place so don't worry about them. once its is apart clean it up good and look for scoring and rough spots, if its all good reassemble it dry, and once it is back together squirt most of the grease that came with the boot into the cup through teh hole where the axle shaft goes, a little on each bearing. put the boot on the shaft and put the rest of the grease in the boot, put teh joint back on the shaft( line it up and a nice tap should lock it in place) then slide the boot up and get it around the cup, make sure to burp the boot as best you can, attach the clips to hold the boot in place. now that its in place work the joint back and forth to get the grease all around the inside of the joint. Viola, ready to be reinstalled
    Jun 2002
    just clamp the axle in a vice,(if you got 1),be careful not to crush it,...grab the C.V by the spline so its in line with the axle and give it a good hit with a soft metal hammer from behind,use a good heavy 1,it'll pop right off,you got no worries about the cage etc coming out .
    You can also change the outer C.V while it is still on the car once you got the hang of knocking the C.V off....and yes, i've done this many times if you're wondering
    I can scan some diagrams on how to dismantle C.V if you like and email them to you
    Oct 2001
    please do pete ! could you send them to [email protected] ( not zipped please )
    thanx a lot guys for the help ! you are the best ! :super:
    MIKE
    Jun 2002
    on it's way...hope it helps
    Oct 2001
    Pete ! i love you man ! very nice explanation and pics !
    i am gonna try that on some lying around axles as you said !
    thanx again !
    MIKE
    Jun 2002
    no problem,pleasure to help out.........:smokin:
    Oct 2001
    just tried that on my dad's old axle ( peugeot ) and it poped with a hit ! and got it back in ! woooooohooooooo !
    now i wonder why the service manual tells us not to diassemble the joint !
    MIKE
  1. CV joint boot, Replace???
    By ericn33 in forum 3geez Accords
    Last Post: 09-13-2008, 04:25 PM
  2. Ball Joint...foiled by an effing ball joint...
    By Tailfin in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-21-2006, 11:40 PM
  3. Egg & Chicken : Ball joint OR the boot?
    By visionguru in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-22-2005, 02:40 PM
  4. lower ball joint/steering boot
    By winkie45 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-22-2003, 08:40 PM
  5. Replies: 7
    Last Post: 12-29-2002, 07:29 PM
