Results 1 to 5 of 5
Thread: Timing Adjustment Question
    Not like a rock's Avatar
    86 EXi(sold), 89 SE-i auto, 89 SE-i 5spd
    Prince George, North BC, Canada
    I know this sounds like a common question, but I ran a search and didn't get anything useful:
    On the timing marker on the distributor, how many degrees does each notch represent? I can't see any numbers on mine. When the advance is disconected, the pointer is at 0, and when the advance is connected the timing moves just below (clockwise) the next notch after 0. If anyone has adjusted their timing recently, does this sound right for EFI A20A3.
    Perfection is simply a matter of replacing parts.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    I'm not sure if different years of 3gs have different timing, it also depends on what tranny you have. But do check under the hood for the sticker. It would say how much timing (probably 15 +- 2 degs). The correct timing mark should be colored red on the flywheel.
    I'm aware that the correct timing should be 15B, but I don't know how many degrees each line on that little marker represents. I'm thinking that each line is 5, but I'm not sure. I'm just trying to determine whether or not I need to inspect the timing belt incase it's off by a notch.
    carotman's Avatar
    Montreal South Shore
    when you apply full vacuum, it should reach the 15 degrees mark (there is a second mark)
    I need these parts!
    Red <<--
    So, the pointer should be right on the line below the red marker?
    If it's at the red marker with the vacuum plugged, but moves way past the second marker with the vacuum connected, does that mean that the timing belt isn't on correctly?
    Thanks
  1. 88 Accord Timing Adjustment
    By Xaisk in forum Carburetor Tech
    Last Post: 03-03-2010, 10:52 AM
  2. Timing Adjustment
    By zildjian102 in forum 3geez Accords
    Last Post: 02-18-2010, 01:01 PM
  3. Timing Adjustment=GOOD
    By HondaBoy in forum Performance
    Last Post: 07-22-2006, 02:42 PM
  4. timing adjustment
    By rdn in forum 3geez Accords
    Last Post: 09-16-2003, 11:37 AM
  5. Timing belt adjustment?!
    By 89AccordNate in forum 3geez Accords
    Last Post: 01-29-2003, 07:00 PM
