Results 1 to 3 of 3
Thread: black light/ neon question
    DX User badb0i's Avatar
    Exclamation black light/ neon question
    i want to insert a bunch of black light/neon inside me car without directing them to the cigarette outlet for a clean look. I've seen them on many cars before.
    ______
    A honda isn't always rice. Like my Accord, Its in a class of its own.
    LX User 86hatchbackLXi's Avatar
    Jun 2002
    The White Hatch
    Guilford, CT
    find any 12v source and wire in a switch and fuse, its very easy
    86 white hatch LXi with 5spd swap and full system.
    Feb 2003
    1988 Honda DX coupe
    Penobscot Maine
    I wired some strobes in my truck directly off the battery. First I mounted the strobes where I wanted them, then ran wires from them to the transformer. Then the negative wire from the transformer was wired to the negative battery terminal. I then ran a wire from the postive battery terminal through the firewall and into a switch mounted in the dash. Then another wire was wired from the switch back to the transformer. If you buy a strobe kit designed for cars, it should come with a transformer. If it has a cigarette lighter adapter, you can cut that off and hardwire it directly to the battery. And the cool thing about having the switch in the dash is that you can rig as many strobes up to one switch as you'd like. I have all mine rigged to one switch, so when I flip it all my strobes come on. You could also do seperate switches for each light you want, too.
    If I see another vehicle with a bumper sticker that reads "My other car is a Nimbus 2000", I might have to rear-end them.
  1. FS: 15" Neon Light
    By MrBen in forum Trading Post
    Last Post: 03-23-2004, 07:48 PM
  2. 1st gen neon sideskirts and fixed corner light gap!
    By hondamanlxi in forum Classic Honda Pics & Videos
    Last Post: 02-09-2004, 02:12 PM
  3. Dash Light Black out..........
    By bigpoppa88 in forum 3geez Accords
    Last Post: 12-31-2003, 09:44 AM
  4. neon question
    By 89bumblethumper in forum Interior & Exterior Care
    Last Post: 08-31-2002, 09:27 PM
  5. another neon question
    By 88 Accord DX in forum Interior & Exterior Care
    Last Post: 08-22-2002, 05:12 PM
