Results 1 to 15 of 15
Thread: audio problems
    1989 Honda Accord LX-i 2 door
    St. Louis, MO
    Angry audio problems
    well you see if i have a 500 kenwood running my mids and highs and a 250 running my alpine type S 10. the problem is when i am listening to it the mids and highs just cut out and my bass is the only thing hitting then all of a sudden they both just stop working. sometimes it is the other way around all of it stops working and then just the sub will hit and finally it will come back on after a few seconds. does anybody know what the deal is with it. i had my alternator checked to see if maybe it wasn't keeping up with my battery and that is why it was shutting my stearo down but they said it is working fine. so i have no idea what the problem is. well if anybody knows anything or has the same problem just let me know. thanx.
    HostileJava's Avatar
    Northampton, PA
    Sound like a grounding problem, like somthing is going to ground temporarily that shouldn't be. How do you have everthing hooked up? What outputs do you have on the back of your head unit and what is each connected to?
    yeah if you have bad grounding either at the amps or the battery, the amps can go thermal and shut down eventually, also having a poor connection at the power terminal that can do it to, so can not having a big enough cable. For that kind of set up you should be running 4 gauge at least.
    LX User 86hatchbackLXi's Avatar
    Jun 2002
    The White Hatch
    Guilford, CT
    go re-check all your wiring, especially your ground and your remote turn on wire, if these are loose your music will cut in and out. also check your RCAs in the back of the head unit, becuase if they cross or ground out you will have problems. if this doesnt fix it try getting a cap, or upgrading your wiring.
    86 white hatch LXi with 5spd swap and full system.
    i have to agree. sounds like grounding or battery cable to me.
    check all the wires, and make sure they are not striped too far and have bare naked wires sticking out.
    LX User catalin's Avatar
    1986 Accord Hatchback
    Surrey, BC, Canada
    So Pntbal, one thing you didn't mention... How loud are you playing the system when it shuts down?? Also when it does shut down, do the amps stay lit?
    When the alternator was checked, did someone actually telll you what voltage it was producing when it's under load and the engine is running?? Very important thing to know..
    St. Louis, MO
    it doesn't matter how loud i have the volume turned up. it can be just one notch up or it can be all the way up. also it doesn't matter what time of day it is. because at first i kinda thought that maybe during the day the amps are just getting hot from inside the car and shutting down but that isn't it because it does it throuhout the day or night.
    goldyaccord's Avatar
    Ford work Van
    Tigard, Oregon
    You have a bad ground. I had that problem before..
    sorry guys v8's rule
    1987 Honda Accord (R.I.P.), 1990 Eagle Summit, 1994 Chevy Silverado 2500
    Montana
    I agree bad ground or maybe even too small wires, if those dont work then try making sure your engine ground/battery ground are large enough, youd be surprised what that can do for power needs.
    If it dont go fast or go boom then it just aint right.
    Surrey, BC, Canada
    You still haven't said anything about the amps lighting up or the alternator itself.
    It's easy to just simply assume that it's 'a ground', I do think that everyone is on the right track. It sure seems like it's a power delivery problem. It could be the amp itself too..
    If you describe the system a little more or even take some pictures for us I'm sure we could come up with a better guess as to what's wrong with it.
    St. Louis, MO
    yea thanx everybody for the help i found out the problem. i was outside awhile ago looking at the amps to see if i could figure out what was up with them and i looked real close and one of the wires was lose so that is why everything kept shutting down.
    Montana
    Sure your welcome, isnt it always some thing frickin stupid like a loose wire........................
    St. Louis, MO
    yea i know those damn little things are always the problem. i mean you think it is something big but it turns out to be something like that. i am just glad i didn't go out and spend any money on anything to get it to work and it turn out to be this.
    Montana
    yeah, ive done that before and then turns out its like a short or somethin it sucks.
    People bring there stuff in to the shop i work at all the time and pay the 20 bucks to have it looked at plus parts and labor if it needs fixing, but most of the time its a bare wire or a short or some other stupid thing like that, and they wasted 20 buks, but hey at least im paid to do it, hehe.
    $20 says it was the remote wire
  1. SE-i audio system problems
    By Blkblurr in forum 3geez Accords
    Last Post: 11-13-2005, 08:58 AM
  2. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  3. jl audio
    By mmafiak in forum Interior & Exterior Care
    Last Post: 12-08-2003, 04:12 PM
  4. problems after problems, peep this shit
    By mugenprelude86 in forum 3geez Accords
    Last Post: 08-06-2003, 11:31 AM
  5. Go here for audio help!
    By 87DXHatch in forum Interior & Exterior Care
    Last Post: 08-08-2002, 08:29 PM
