Results 1 to 17 of 17
Thread: Does your car sit higher on one side after being lowered?
    Jan 2003
    89 LXI
    USA
    I just wanted to know
    After your car was lowered with lowering springs does it sit lower on one side?
    I am very hmmm shall I say meticulous with my car.
    After being lowered it still sits higher on the passenger side.
    (I did double check the strut setup (you know the bushings bump stops etc...) What could it be?
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    I have heard of a couple of people that mentioned something to that effect. Although the majority of the people don't notice anything out of the ordinary. I have a set of Sprint 2.25in lowering springs and I checked with a few people that currently have them on their car and they said that the height is equal. I’m just waiting to get some shocks and the springs are going on...
    BTW what enkeis do you have? I have 16in CDR9's with the same tires that you have.
    ~Nathan~
    ~StOcK PiCs~
    Jan 2003
    89 LXI
    USA
    LOL ...I too have cdr 9's.
    Nov 2001
    SWEET!!! Thats funny shit man... If you could get me some pics of your 15's I would be greatful... Lol... some tire and rim setup!
    ~Nathan~
    ~StOcK PiCs~
    AZmike's Avatar
    Tucson, Arizona
    My H&Rs lowered the left and right equal amounts. There were some small differences in ride height before I started that remained with the new springs. The front driver side corner was 0.2" lower than the front passenger and rear driver side, which were the same. The passenger side rear was 0.2" higher than the passenger front. All measurements were taken from the jack points near the wheels.
    Mike
    SEi User johndej's Avatar
    1989 Accord LX-i 5 speed hatchback
    Culpeper, Va.- home, JMU (Harrisonburg, Va.)- school
    hmm... thats odd. could it be that something is bent or not lined up right?
    "Eat, Drink, and be Merry!"
    1988 Honda Accord DX Sedan
    San Bruno, CA
    not sure, but since most of the time, you are the main passenger in the car, the springs on the driver side will sag over time, while if you don't drive passengers around, the pasenger side springs won't be affected that much?
    just an assumption.
    Mine was different... I just adjusted the coil overs some to line it up. I had them both set to the lowest setting so I know they were even to start with.
    Jan 2003
    89 LXI
    USA
    Here is at least something ..
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    coilovers rule! lol
    Travis
    Jan 2003
    89 LXI
    USA
    Originally posted by DXHATCHBACK
    coilovers rule! lol
    Travis
    YUP
    What struts are you using and do u have a camber kit?
    Right now coilovers/proper struts are something to think about later on (I want to get the strut/coilover setup right plus a camber kit. I figure that would run me over 900 dollar)
    AZmike's Avatar
    Tucson, Arizona
    just an assumption.
    The off center position of the engine, transmission, and steering column probably contribute to this more than anything else. The weight of a driver or passenger is still pretty small compared to the car's ~2700 lb weight. So if the springs were to sag they would probably be about the same on both sides.
    Mike
    NORTH BAY ONTARIO
    well... im running a full bodied setup
    its a all in one setup
    its fairly stiff and its real easy to install...
    there are two major problems with them tho
    the rear didnt come with a top hat so i had to get the top ring of the old springs welded to the new coil over spring
    and the front strut body was 2 inches too long, so i had to cut em and weld the top back on
    i bet if you say something when you order, they will fix it
    http://www.truckn-store.com/product....t.asp&ID=23891
    (they are the 3 rd pair from the top and the 14th pair from teh top for the rear)
    they are called LOW BOYZ and they are 240 bucks a pair
    so instead of like 900 bucks, you can get lowered for 480 bucks
    and the struts are life time warenty, if they break, send em back
    this company has been around for a long time, they are the old RICKY RACER and they always have a 2 page ad in SUPER STREET , IMPORT TUNER and most truck mags get multiple page ad's
    Travis
    SEi User cdscowboy's Avatar
    90 Nissan 240sx coupe
    Corvallis, OR
    I'm having a similar issue with just my stock springs. Only it's lower on the passenger side, not driver side. I have no clue as to why it's doing that. Is there something that needs adjusting or something??? Any help would be greatly appreciated!!
    AZmike's Avatar
    Tucson, Arizona
    There is not adjustment unless you want to try and find something to use as a shim between the lower corner's spring and its perch. Do all of the suspension parts look ok? Just how much lower is the passenger side?
    Mike
    carotman's Avatar
    Montreal South Shore
    My car is lower on the passenger rear side... it was like this with the stock springs and it still is with the Neuspeed springs....
    All the weight of the car seems to be on the driver side. The engine is on that side, all the steering colums and controls are there, plus the gas tank is on that side of the car.... That's the only explanation I found so far
    Corvallis, OR
    I haven't inspected the suspesion parts really closely, cause I didn't notice it till I got my wheel put back on and I didn't have time. I'd say it's a difference of about an inch or so...thereabouts. You can notice it when you're driving/riding.
  1. higher redline
    By Nik247 in forum Performance
    Last Post: 07-03-2009, 09:23 AM
  2. FI pistons have higher c/r????
    By OldSkoolA20accord in forum Classic Honda Community Chat
    Last Post: 01-16-2009, 01:12 PM
  3. Hesitation at higher RPM's
    By sb_hbackDX in forum Carburetor Tech
    Last Post: 12-22-2005, 07:03 PM
  4. HiGhEr rPm'S
    By troutz15 in forum Performance
    Last Post: 07-22-2004, 12:59 PM
  5. Anyone have a higher amp. altenator?
    By guaynabo89 in forum Interior & Exterior Care
    Last Post: 03-14-2003, 11:34 AM
