If i lower my 89 LXi 2 1/4" all the way around will i still be able to put on 17"rims with out any tire rub?
89'Accord LXi
Mods:
Pace-Setter Cat-Back
Weapon-R Intake
As long as you use a compatible size tire, you can do it. Here is a tire size calculator that will help.
Click this link
thx man
89'Accord LXi
Mods:
Weapon-R Intake
run 205/40-17" tires and 40mm offset and you should have no problems.Originally posted by scrappy24
Now I d
