Results 1 to 4 of 4
Thread: how to change the power steering fluid "long pipe" ?
    Jul 2003
    My old one crack to to a frontend collision. The problem now is that it would leak out the power steering fluid, so I cannot turn. I already bought the new long piping, but have no idea where to start. Should I take off the bumper ? Is it hard to take it off / put it back on again?
    Made in Japan
    LXi User jlaccord89lxi's Avatar
    '01 Accord EX Coupe
    Nova Scotia, Canada
    are you talking about the power steering line that goes from the pump, accross the front of the engine, then down behind the engine to the cross member? If that is it, you won't need to take off the front bumper.
    AZmike's Avatar
    Tucson, Arizona
    He's talking about the PS cooling line. The bumper is easy to remove. First remove your signal lamps. 88-89 models have a vertical screw accessed through the fog lamp cover. 86-87 models have a pair of screws on the front of each lens. Then remove the two bolts behind each lens and slide the bumper forward. I haven't had to replace the cooling loops myself, but removing the bumper is definitely the first step.
    For next time, a question like this should be in the technical section.
    Mike
    Jul 2003
    Thanks , I will give it a go this week.
    Made in Japan
  1. preheater hose (aka "hot air pipe")
    By bongbang in forum 3geez Accords
    Last Post: 06-19-2009, 07:12 AM
  2. how to change the power steering fluid "long pipe" ?
    By legend9 in forum Classic Honda Community Chat
    Last Post: 07-22-2003, 10:46 AM
  3. Power steering fells "stuck" HELP ME PLEASE
    By Bullfrog in forum 3geez Accords
    Last Post: 01-25-2003, 09:29 AM
  4. Test pipe "leaking from catback side"
    By Whitehonda in forum Performance
    Last Post: 11-11-2002, 08:30 PM
