Results 1 to 12 of 12
Thread: Tire Pressure
    Oct 2002
    1988 Honda Accord LX
    New Jersey
    Tire Pressure
    Wassup 3Gz,
    How much air should you put in stock tires 185/70/13 to have your accord running good. I've noticed a difference in the way my car drives now. I used to put 35psi in my stock tires and my car ran heavy. Now, I've been putting 30psi in my tires and my car is running like its on air. It rides good and picks up good too. I'm just curious to find out what do you guys put in your stock tires. Also, is it true that the heavier the tires are, the more you may have problems with axles, tie rods, ball joints, etc....
    holla back,
    Nov 2000
    There are going to be as many answers to this as there are respondents. I used to use the maximum printed on the tire (usually 35). The car rode really hard and the tires wore out rapidly. Following NTB's recommendation I use the pressure printed on the door jamb sticker (26) and they ride better and last longer. A lot of it has to do with the maximum load the tire can handle. If you multiply that by four (four tires - duh!) and divide your car's weight into it you can estimate what pressure you should be using. In my case, with a 35 psi max tire, it works out to right at 26. I guess Honda knew something when they made that recommendation.
    shepherd79's Avatar
    Falling Waters, WV USA
    I used to put 28 all the way around, but now it is 30 al the way around. i get better gas mileage.
    Nov 2000
    It's hard for me to tell about the gas mileage because I switched to primarily in town driving right at the time our area switched to reformulated gas so it was a double whammy against the gas mileage.
    Nov 2002
    Ridin Dirty in New York
    Yea i run in the mid 30s for tire pressure, and i notice a little increase in handling and mileage. It does make the ride suffer a little tho
    Oct 2001
    87 Accord EX , 5spd , Manual
    i ran 28 and now i run 30 ! better gas milage ride less comfortable !but that's barely noticable !
    MIKE
    88fasthatch's Avatar
    88 accord dx hatch
    santa rosa, ca
    air pressure
    I put 42 psi in my 205/40/r17's and I love it. but when I had stock tires and wheels I ran 35-38.
    17"enkei cdr 9 with falcon tires
    dropped to the ground
    k@n inhale and flowmaster exhale
    Justin86's Avatar
    Medford, Oregon
    I ran 25PSI to get some better handeling.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    you would get worse handling with 25 PSI.....
    and it is true that the heavier your wheels and tires, the harder it is on the drive train.. thats why i wanna sell my wheels and tires and get some light weight 15's or 16's
    Travis
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    I put in about 32 PSI all around.
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
    Oct 2001
    tire wear too !
    MIKE
    shepherd79's Avatar
    Too much tire pressure or too low tire pressure will cause tire wear. Tire will wear out about 2 times faster.
    When tire gets hot, the pressure will rise about 2-3psi.
    Plus not to mention too much presusre may explode the tire, and too low pressure will blow the tire out.
    I think there is a reason HONDA engineers decided on 28psi for cold tire.
  1. Tire Pressure Question
    By import racer in forum Classic Honda Community Chat
    Last Post: 04-11-2011, 01:42 AM
  2. tire pressure
    By djcslice in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-04-2006, 09:43 PM
  3. Winter tire pressure
    By meangreenLXi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-04-2004, 05:01 PM
  4. tire pressure ?
    By ACCORD EX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-17-2003, 09:19 PM
  5. tire pressure, HELL YEA
    Last Post: 10-01-2002, 12:53 PM
