Results 1 to 4 of 4
Thread: DIY Throttle body porting
    91 Jetta
    Midwest
    anyone know how to bore the throttle body a bit bigger? ..i have a dremel to grind it out, but im not sure what to grind and where to grind
    PhydeauX's Avatar
    Eastern Penna
    Thats not really a dyi unless you have access to a machine shop. All you do is make the bore bigger, but it needs to stay perfectly round and you need a bigger throttle plate to match the new bore diameter. Its close tolerance stuff and you really need a cnc setup to do it.
    andy
    91 Jetta
    Midwest
    well ive seen some websites with people who have done it with a dremel, just wonderin
    PhydeauX's Avatar
    Eastern Penna
    I wonder what they actually managed to do with the dremel, maybe made the inlet to the tb bigger, but thats really pointless. The whole idea behind it is to get a bigge throttle plate, which would have to be custom made, and is involved (the edges need a certian degree of taper, its not just a flat copper disk) and the area where the plate sits has to be enlarged to accomodate the new plate. The tolerances are very very close and probalby couldn't be achieved even by expierenced hands with a dremil with out putting alot of time into it.
    andy
  1. 87 throttle body
    By ghettogeddy in forum Wanted
    Last Post: 08-08-2010, 06:15 AM
  2. porting & polishing the throttle body and intake
    By 3gn86lxi in forum EFI Tech
    Last Post: 08-11-2004, 09:02 AM
  3. Where is the throttle body?
    By wolfort in forum Carburetor Tech
    Last Post: 04-10-2004, 01:10 AM
  4. Porting throttle body and heads
    By Honda88LXiBoy in forum 3geez Accords
    Last Post: 08-10-2002, 05:07 PM
  5. Throttle Body ?
    By GreenMachine in forum Performance
    Last Post: 06-16-2002, 05:31 PM
