Results 1 to 7 of 7
Thread: 35 mm???
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    35 mm???
    i have read so many times that we have to run 40mm or higher offsets on our cars... now i have come to the point that i am tired of 17's heavyness and harsh ride... i want 15's
    so i go to my favorite wheel store online and find my dream wheels... 15X7, 4X100 and 35mm offset...
    so what would happen if i try to run a 35mm offset with 205/50/15s and a 2.5 inch drop? will it work?
    Travis
    NORTH BAY ONTARIO
    these are the wheels BTW
    Travis
    Oct 2001
    87 Accord EX , 5spd , Manual
    man those wheels look good !
    i think if you got with lower than 40 mm offset you'll rub against the fender !
    MIKE
    NORTH BAY ONTARIO
    ok.. i really like that style...
    JIM???
    whats the werd on 35 mm??
    Travis
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    It'll rub the fenders. I have 35mm and lowered 2" and the rear is rubbing when I go onto a slant road or hit bumps. I'm not sure even if you push the lip up it'll tuck under.
    NORTH BAY ONTARIO
    aww fuck... well.. im thinkin of grafting front fender lips onto the back because they are much bigger.. it will give a fender flared look
    maybe they will tuck then..
    Travis
    86 Honda Accord LXI HB 5-sp
    Central California
    No can do, sorry.
    Keep on looking I'm pretty sure I've seen that same style several times across the net. Keep on looking, don't screw yourself over with 35mm. It would work with 195/50-15, but those look puny on the car, well their undersized so that's why they look funky IMO. Anyways, keep on looking man, your out to fix a problem, don't create another one.
