I have a problem, My brakes when i stop arent wanting to stop the car. Someone mentioned Bleeding them so i did. And now they still wont stop. The brake pedal all the way to the floor.HELP!!!![]()
[QUOTE]Originally posted by Morbid Intentionz
Its probably your master cyclinder, and/or rubber brake lines.
Rooz
Wheres the master cylinder and how do i tell if its bad?
Yea either your master cylinder is bad or you have a leak some where. If you have a leak you should notice your brake fluid level getting lower as you use the brakes. If the cylinder is bad and you have no leaks your braking should get stronger as you pump the brake. It will take at least 3-4 pumps of the brake.
Wait, what?
Dont you mean ISN'T bad? Also, if you brakes don't firm up with the car off, your booster is bad.
