Results 1 to 10 of 10
Thread: do i need bigger injectors if i got a 272 cam
    Accord7SE_i's Avatar
    Jul 2002
    89 Honda accord se_i
    Gilbert,AZ
    do i need bigger injectors if i got a 272 cam? I jsut want to know if opening the air way more = i need more fuel!
    I got the need,The need for speed!!!
    89' accord se-i
    mods: HEHE NOT TELLING!!!!
    Jul 2002
    Gilbert,AZ
    LOL upps!!!
    do i need more fuel if a have a cam?
    89' accord se-i
    1988starter
    Guest
    You should not have a problem as far as grinds go the 272 is quite mild.
    Jul 2002
    Gilbert,AZ
    bigger cam, more fuel?
    Sence im getting the 272 cam from delta do i need more fuel sence im giving it more air?
    89' accord se-i
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    hmm
    bore out the throttle body, and get a B16 manifold or B18c5 manifold... that will open your intake side up to get more air. Then you can worry about injectors, fuel rails and FPR's.
    Just the cam alone will only get you so far.
    Jul 2002
    Gilbert,AZ
    LOL!!!!
    I already have the b16 head and the 32 throttle body what im asking is if a get that 272 cam will i need more fuel sence the cam will be giving it more air?
    89' accord se-i
    Justin86's Avatar
    Medford, Oregon
    Don't you mean a B16 intake not head. So far I don't think anyone has got the B16 head swap done and working. Unless you did the B16 swap and don't want to tell anybody.
    With that cam you probably don't need bigger injectors, but you can. I'm not sure on what the stock cc, something like 280cc. Get a little bit bigger injector and a fuel pressure regulator and that will work.
    A20A1's Avatar
    Sep 2001
    What I was saying was the cam won't give you a big increase in air unless you have other mods. It's good you have the B16 manifold.
    But just to go back a bit... You can increase lift and duration all you want, but the stock throttle body and intake manifold is a restriction on the intake side. Just as the header, exhaust pipe, cat, and muffler is a restriction on the exhaust side.
    ... and yes you need more fuel with more air, my suggestion to you is run your own tests or do a search on fuel system upgrades for EFI.
    have fun tuning...
    Jul 2002
    Gilbert,AZ
    um.....um....... That is what is what made to do.
    89' accord se-i
    Justin86's Avatar
    Medford, Oregon
    Yea it is suppose to give you more air, but with a stock restrictive intake you won't get the full benefits. If you have a CAI and port & polished manifold that will help the air get in easier.
  1. bigger injectors
    By 88lxi-shortram in forum Performance
    Last Post: 11-10-2010, 09:07 AM
  2. bigger cam
    By evil88accordLX in forum 3geez Accords
    Last Post: 03-31-2008, 03:13 PM
  3. Bigger engine??
    By sk8ordie133 in forum Performance
    Last Post: 05-17-2006, 08:46 AM
  4. bigger injectors?
    By b8er in forum Performance
    Last Post: 10-19-2005, 12:39 PM
  5. bigger injectors?
    By pervasto in forum Performance
    Last Post: 08-03-2004, 09:27 PM
