Results 1 to 5 of 5
Thread: Black smoke
    SEi User od2681's Avatar
    Nov 2002
    2003 Infiniti G35 sedan
    Houston Tx
    Black smoke
    alright people....I know that my car runs rich and yesterday I told my friend to look at my exhaust and see if smoke came out....well around after 4000 rpms my car throws black smoke and then comin back down to around 4000 rpms it throws outa little bit again...it dont throw smoke in regular drivin.....My dad said its most likely cuzz my injectors are over flowin...cuzz they are too old....so i might just go down to the junkyard to pick up some used ones that work better for 80...
    I wanted to ask you all that what other problem could it be instead of it being injectors...cuzz usually black smoke is cuzz of the fuel mixture right??
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    well richness does cause black smoke... but if you don't burn the mixture properly you get black smoke as well.
    You can do some general maintainance, throw on some TB clener, check the plugs... stuff like that.
    shepherd79's Avatar
    Falling Waters, WV USA
    do you get any codes on ECU?
    i think something wrong with your sensors.
    Nov 2002
    Houston Tx
    the only code i have is for the egr....
    Justin86's Avatar
    Medford, Oregon
    Try taking off your egr and clean it up and then put it back on. I was getting a code 12 and my car was having trouble ideling and I cleaned the egr and the problem went away.
  1. Black smoke, Help please
    By Denis in forum 3geez Accords
    Last Post: 02-07-2011, 04:16 PM
  2. JDM '87 - run rough with black smoke after rebuild head
    By Teratani in forum Carburetor Tech
    Last Post: 02-17-2009, 01:09 AM
  3. Black Smoke During Warm-up
    By MIK3 in forum Carburetor Tech
    Last Post: 02-28-2005, 08:47 AM
  4. black smoke
    By hondaisthebest in forum 3geez Accords
    Last Post: 07-09-2002, 09:42 PM
  5. Black Smoke
    By ‹^› ‹(•¿•)› ‹^› in forum Performance
    Last Post: 06-02-2002, 08:58 PM
