Custom JE Pistons brand new and in the box, includes wrist pins and Hastings piston rings.
Here's the specs from the side of the box:
Bore = 3.266
Comp Height = 1.170
Forging = 81MD4
Pin Dia = .827
Pin length = 2.250
Dome = none
Top Ring = 1.2 mm
2nd Ring = 1.5 mm
Oil Ring = 3.0 mm
Piston Weight 287 grams
I called JE with the job number and they told me this about the pistons:
-10:1 compression.
-Suitable for racing - yes.
-Suitable for turbo and nitrous - yes (you probably won't want turbo with 10:1 compression, but it has been done).
-Lightweight aluminum alloy.
-Use rods of stock length.
-Pistons are stock bore and not oversized.
If you put these in your car, I recommend at least having your rods shot-peened if not replaced with custom rods.
$300 plus shipping.
